Adding Mass to Subwoofer Cabinet
Old 19th June 2012, 03:36 PM   #11
GM is offline GM  United States
GM's Avatar
Right, mass loading a speaker is best done by adding top weight, with a heavy potted plant being a popular choice with you-know-who .
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th June 2012, 03:50 PM   #12
chrisb is offline chrisb
With the current popularity of synthetic stone ( Quartz, etc) counterops, you might well be able to find offcuts available at local fabricators that could yield a suitable sized piece. I've been able to reclaim sufficient for several base slabs at zero cost from a local shop, but unless you have appropriate wet saw and polishing tools, the cutting and finishing the exposed edges could cost set you back a few $ - (try the ole "Friday afternoon "24 pack" incentive)
A couple of dabs of silicone or even high strength double edge carpet tape, and that slab ain't going nowheres.
like my mind, this space intentionally blank
Old 19th June 2012, 03:58 PM   #13
Rullknufs is offline Rullknufs  Sweden
Rullknufs's Avatar
GM
I've added three garden stone slabs at 14kg/each + my two amplifiers on top of my subwoofers. They aren't going anywhere
My audio and DIY blog: http://phimusic.blogspot.se/
Old 19th June 2012, 10:06 PM   #14
Ephai is offline Ephai  United States
I'd say. I was thinking like a 0.4 cubic foot chamber for about 40 lbs. (~18kg) of extra weight would suffice.
Build a form to fit and pour a 2-3" thick concrete slab to sit directly on top of the cabinet, but detachable. Paint the slab to match.
Unfortunately I have a bit of a height restriction since the sub will be placed behind a reclining couch, but have an unlimited amount of space available for the depth. Hence the thought to put a sand filled chamber on the end of the cabinet opposite the subwoofer.
I hope it will work. It might make for a slightly awkward looking enclosure though (long and skinny: 24" x 12.5" x 12.5").
Old 20th June 2012, 12:55 PM   #15
fastbike1 is offline fastbike1  United States
You can build the sub down firing in your cab. It only needs 2-3 inches clearance underneath.
I was so much older then, I'm younger than that now.
Old 20th June 2012, 01:47 PM   #16
GM's Avatar
If the driver's compliance can handle it long term: Parts Express - Subwoofer Qualification Formulae For Downfiring Configurations
GM
Old 20th June 2012, 04:30 PM   #17
puppet is offline puppet  United States
In contrast to that build a matching wooden frame and inset the stone. .. if on top, build the box sides/top edges to suit. Now a guy just has to worry about the edges of the stone .. 1/8" chamfer or so.
Adding Mass to Subwoofer CabinetHide this!Advertise here!
adding mass to cone Endless Lasers Multi-Way 17 4th October 2012 08:39 PM
Adding mass to Peerless passive radiator Dave Jones Subwoofers 0 1st December 2010 07:34 PM
Adding cone mass fdeck Multi-Way 12 17th June 2009 06:06 PM
Adding mass to PR.... hofffam Subwoofers 1 7th January 2005 12:01 AM
adding mass to subwoofer to lower fs mikesimas Subwoofers 2 13th May 2002 08:15 AM
