#61 |
#62 | |
..But it looks like your 'synthetic blanket' is folded(shouldn't as the bend will be too dense, thus attenuating to much also if the 'blanket' is compressed) and is filling up the entire left out volume in the picture: DSC02895.jpg,~50% is enough. The Glass-wool looks also denser than necessary:You may have to remove this if the box becomes over-damped. Prior to gluing the box-panels air-tight: Use wood-clamps and do a listening test(or perform a measurement) to find out the sonic impact, if necessary to adjust the filling. b
#63 | |
Nelnar, nice build I hope someone provides a good schematic for you. I am planning on using a miniDSP but I will be watching to see what the experts recommend. |
#64 |
BJORNO - really did a test this way and the sound hardly ran through the duct.
Then, the whole blanket acrylic removed, leaving only the glass wool. But it certainly will not seal before doing all the listening tests. So far so thankful my friend. A big hug! NWCgrad - Hello my friend, welcome to post. Look, do something yourself (DIY) is very enjoyable, but you have to devote to your job and mainly rely on friends to whom I could find here. Not wanting to pull Björnö bag, but if it was not for him and his dedication, I would not have gotten this far! As the blanket inside, I put too much. Now I am testing without the acrylic blanket, only with layers of glass wool. Last edited by nelnar; 16th October 2012 at 01:14 PM. |
#65 |
On the issue of the amplifier.
Well, it's hard to find an amplifier with output of 3 ohms, I'm considering getting a automotive module as this model below. Considering also the value is low. Here in Brazil U.S. 110.00. http://www.stetsom.com.br/eng/Detalh...=8364&cat=4639 Well, in this case, I will have to acquire a source of 12v to 14v with 50 amps. I thought this fountain, where the seller assured me that will supply the amplifier. http://www.aliexpress.com/item/600W-...621228646.html |
#66 |
Hello friends.
Now is the amp, but the power supply does not! As I was anxious, I called the module in a car battery yourself, of course, with a safety fuse. The source was not from that link posted above, but this one below: Wholesale Product Snapshot Product name is Free shipping,New 600W 12V50A Switching Power Supply For LED Strip light,220V/110V AC input,12V output +more DHL Free shipping ************************************************** ****************************** Below is the photo of the tests. ************************************************** ******************************* reminding the specifications of the subwoofer: POTÊNCIA RMS: 300-400watts IMPÊDANCIA: 6+6ohms SENSIBILIDADE: 88db Revc=2.300 Ohm Levc=889.758u H Fo=28.582 Hz Sd=53.093m M² Md=44.000 g BL=9.648 T·M Qms= 6.989 Qes= 0.532 Qts= 0.494 No= 0.440 % SPLo= 88.5 dB Vas=103.554 Ltr Cms=258.705u M/N Mms=119.852 g Mmd=105.783m Kg Xmax= 13mm * Based on the specifications of the subwoofer, which would cut the correct settings on the amplifier STETSOM venom v.600 2ohms? High pass filter? Low pass filter? Last edited by nelnar; 21st October 2012 at 12:03 AM. |
#67 |
#68 | |
Nice video! thank you.
What do you think of the result?
![]() Quote:
#69 |
nice project.
how does it sound?
one good thing about music ,when it hit you feel no pain. so hit me with music.
#70 |
For now, this testing phase, precise fit lining, making closing the lid, because the audio output should be in 96mm. But, I'm liking what I'm hearing. Very good!
| 10" Subwoofer < $100 | 5toes | Subwoofers | 8 | 25th April 2011 11:12 AM |
| Nice DIY LT Home Theatre SubWoofer | BillPetrie | Subwoofers | 0 | 26th August 2008 12:05 AM |
| subwoofer <$100? | gychang | Subwoofers | 16 | 3rd February 2007 02:49 AM |
| My subwoofer Crossover & LT | merlinx76 | Chip Amps | 15 | 12th February 2005 08:08 PM |
