SUBWOOFER LT
SUBWOOFER LT
Old 1st September 2012, 03:56 AM   #31
nelnar is offline nelnar  Brazil
Björnö. Please friend. Respond if the design is correct!
And what would be the fill area?
Old 3rd September 2012, 03:01 PM   #32
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi Nelnar,
You have designed a TL using my numbers for a T-TQWT that of-course can be morphed into an OD-TL.
For this case and for your rear terminus TL, I would decrease the line length to 310-320 cm in order to tune just below the Driver fs, that is :
The internal height would be 155-160 cm.. all other dimensions unchanged.
I rec. you to do so too with your TL as the FR will almost be unchanged.
b
Old 3rd September 2012, 11:23 PM   #33
But I wanted the T-TQWT same.
Once the measures are certain to T-TQWT, what is wrong?
is the position of the speaker?
I even design more cameras for this project!
Old 3rd September 2012, 11:29 PM   #34
jwmbro is offline jwmbro  United States
jwmbro's Avatar
For a TTQWT, the speaker must be inside, on the divider, and not on the outside of the box.
Regards, James
Old 4th September 2012, 12:22 AM   #35
Very grateful Björnö and Regards, James.
I think now I understand!
For T-tqwt, it would be as below??
Old 9th September 2012, 12:23 AM   #36
Originally Posted by bjorno View Post
Hi Nelnar,
b
Björnö.
This decrease in line 330 for 310-320 is only for OD-TL, or also T-TQWT?
NOTE: The first image above is wrong. Sorry. (please disregard).
Old 16th September 2012, 11:36 PM   #37
Please make sure it is correct for t-tqwt?
Old 17th September 2012, 12:03 AM   #38
Hi nelnar,
Which HR input screen did you use for the layout.
b
Ps. I haven't forgot you but I struggle with computer problems so I may be slow on answering..
Old 17th September 2012, 01:26 AM   #39
Björnö very grateful for your remembrance.
I see you're an enlightened person.
Well, regarding HR.
Were the same as you posted.
What are these:
Old 17th September 2012, 01:30 AM   #40
You had told me to slightly decrease the transmission line to + or - 10cms.
Well, I understand that is for OD-TL.
The question I want to know if it is also to diminish the case for T-tqwt?
SUBWOOFER LTHide this!Advertise here!
10" Subwoofer < $100 5toes Subwoofers 8 25th April 2011 11:12 AM
Nice DIY LT Home Theatre SubWoofer BillPetrie Subwoofers 0 26th August 2008 12:05 AM
subwoofer <$100? gychang Subwoofers 16 3rd February 2007 02:49 AM
My subwoofer Crossover & LT merlinx76 Chip Amps 15 12th February 2005 08:08 PM
