Old 15th June 2012, 10:59 PM   #21
nelnar is offline nelnar  Brazil
I've almost forgot.
I come back to thank you because I wanted you to put all the measures of TL for me. And unlike you, me, studying the charts that you had calculated. And it only helped me! Thank you so much!
Old 15th June 2012, 11:23 PM   #22
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by nelnar View Post
That lesson you gave me into a friend. I would like to understand the transmission line just like you! Tell me how you have any digital book?
As for the softer you use, would be fully trusted?
That same month I will make this T-suboover TQWT, and when you are ready, post here, with special thanks to you!
Thank you and I apologize for my impatience!
a hug
Thank you nelnar, you wrote kind words..
Here are a few Url's for you to dig into :
The Nature of the Quarter Wave Resonator
Quarter Wavelength Loudspeaker Design
Hornresp for Dum... hmm... Everyone - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
Easy Horn Spreadsheet for Dummies
I use the softwares that are 'the tools of trade' here at DIYaudio as they give very good results so far as I can see ..
b
Old 19th June 2012, 11:47 PM   #23
b
Bjorno which of the two amplifiers you recommend for this subwoofer:
Bash Bash 500w or 300w?
Old 9th August 2012, 01:57 AM   #24
Default new driver NAR
Bjorno when he finally managed to keep all the cash to make the subwoofer, the speaker makes the NAR, is no longer manufacturing. Moved to this model, as follows:
Not wanting to abuse you, and considering that I broke the head to get the new calculations, I did not get anywhere.
You could calculate for me?
Below the model and specifications:
Subwoofer 1266-SW-3
POTÊNCIA RMS: 300-400watts
IMPÊDANCIA: 6+6ohms
SENSIBILIDADE: 88db
Revc=2.300 Ohm
Levc=889.758u H
Fo=28.582 Hz
Sd=53.093m M²
Md=44.000 g
BL=9.648 T·M
Qms= 6.989
Qes= 0.532
Qts= 0.494
No= 0.440 %
SPLo= 88.5 dB
Vas=103.554 Ltr
Cms=258.705u M/N
Mms=119.852 g
Mmd=105.783m Kg
Xmax= 13mm
Old 13th August 2012, 01:12 AM   #25
I tried using the horn easy to find the parameters that you used to try to modify the driver, but do not know how he arrived at:
S1 = 531
S2 = 511.26
S3 = 196.74
S4 = 177.00
and also the line 287 cm?
Tell me where I'm wrong?
Old 13th August 2012, 01:18 AM   #26
In fact, only the S1 = 531.00 I know. It is the SD. but what else?
Old 17th August 2012, 09:29 PM   #27
Subwoofer 1266-SW-3
IMPÊDANCIA: 6+6ohms
SENSIBILIDADE: 88db
Revc=2.300 Ohm
Levc=889.758u H
Fo=28.582 Hz
Sd=53.093m M²
Md=44.000 g
BL=9.648 T·M
Qms= 6.989
Qes= 0.532
Qts= 0.494
No= 0.440 %
SPLo= 88.5 dB
Vas=103.554 Ltr
Cms=258.705u M/N
Mms=119.852 g
Mmd=105.783m Kg
Xmax= 13mm
Hi nelnar,
Here is an attempt using the new driver:
b
Old 18th August 2012, 12:36 AM   #28
Thank you my friend.
Now let's see if I've learned!
The following measures of the subwoofer, as I understood your project.
Note: You like to do I suffer! (kkkkkkk, just kidding)
For now thank you very much my friend!
You are a very special person.
Old 18th August 2012, 12:44 AM   #29
Have I forgot.
If you allow me, in his honor, put the name of the subwoofer:
SUBJORNOBASS
Old 26th August 2012, 02:18 PM   #30
The subwoofer has arrived, just need your endorsement to finally make the subwoofer!
10" Subwoofer < $100 5toes Subwoofers 8 25th April 2011 11:12 AM
Nice DIY LT Home Theatre SubWoofer BillPetrie Subwoofers 0 26th August 2008 12:05 AM
subwoofer <$100? gychang Subwoofers 16 3rd February 2007 02:49 AM
My subwoofer Crossover & LT merlinx76 Chip Amps 15 12th February 2005 08:08 PM
Copyright ©1999-2013 diyAudio
