SUBWOOFER LT
SUBWOOFER LT
Old 13th June 2012, 02:08 AM   #11
nelnar is offline nelnar  Brazil
And now, you are correct that the Calculations?
Old 13th June 2012, 02:59 AM   #12
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Why shouldn't I.
b
Old 13th June 2012, 10:20 PM   #13
BJORNO!
Many thanks. But even so grateful!
I apologize for your time employee in my project.
However, I think this is all very gratifying.
Tell me one thing:
To calculate the size of the line, the correct calculation would be as follows:
row length = speed of sound / FS / 4
In our case would be>
row length = 344 / 23.80 / 4 = 3.613 cm
In the calculation made by softerware line length was 2.87 cm in
this is just a curiosity.
Another thing:
For graphical analysis box "T-TQWT", the waves were better than the OD-TL?
Old 13th June 2012, 10:55 PM   #14
just one more question:
which the correct design "1" or drawing "2"?
In the drawing "1", this wide-open, ie 31cm + 5.71 cm.
In the drawing "2", only one door for access to the driver, are, is closed, only opened in S4 (5.71 cm), the air coming out only by S4.
Old 14th June 2012, 09:36 PM   #15
sorry:
correcting FS 23.80, 23.40 FS is correct
BJORNO!
Tell me one thing:
row length = 344 / 23.40 / 4 = 3.675 cm
Another thing:
Old 15th June 2012, 01:38 AM   #16
Both are but when you draw imaginary sound rays as in # "1": This gives a false
impression that the sound travels through the Lid, it doesn't !
You have to detach= here remove the Lid in order to convert the T-TQWT into an OD-TL.
Corrected picture here:
b
Old 15th June 2012, 01:46 AM   #17
sorry:
You'll receive answers to post # 13 no earlier than tomorrow, my time.
b
Old 15th June 2012, 03:33 AM   #18
b
Bjorno, the question of T-TQWT, I get this straight.
Let's talk only of the T-TQWT.
This cover you're talking about, is merely to maintain the driver. However, in normal circumstance, is closed? would that be!
As in the drawing?
Old 15th June 2012, 02:03 PM   #19
..Let's talk only of the T-TQWT.
As in the drawing?
Yes! And if you remove the cover(Lid) you have an OD-TL as simple as that.
In OB-TL mode the In-Band FR sloops gently towards lower frequencies = sometimes handy to invoke if room boundary gain considered to high ( corner placements).
The summing of the driver and terminus will be in the far-field for a OD-TL( picking up boundary from the vicinity too) but a T-TQWT can be considered as a Omni-point-pressure-source with comparable low sensitivity for external boundaries interactions.
b
Old 15th June 2012, 10:48 PM   #20
That lesson you gave me into a friend. I would like to understand the transmission line just like you! Tell me how you have any digital book?
As for the softer you use, would be fully trusted?
That same month I will make this T-suboover TQWT, and when you are ready, post here, with special thanks to you!
Thank you and I apologize for my impatience!
a hug
SUBWOOFER LTHide this!Advertise here!
10" Subwoofer < $100 5toes Subwoofers 8 25th April 2011 11:12 AM
Nice DIY LT Home Theatre SubWoofer BillPetrie Subwoofers 0 26th August 2008 12:05 AM
subwoofer <$100? gychang Subwoofers 16 3rd February 2007 02:49 AM
My subwoofer Crossover & LT merlinx76 Chip Amps 15 12th February 2005 08:08 PM
