#11 | |
The home subs flank my 16 foot screen but its for theater use and not really for music so its a tough comparison. I didnt buy the LMSr15's expecting quality with a heavy cone like that with the same motor as the TC 12" runs. Obviously, the 12 has to be better suited to quality with the same motor and less MMS...no? ![]()
#12 | |
For the record, I dont see how a 12db drop in low bass requiring big EQ resulting in big distortion is better SQ. I tried sealed box alignments and hear nothing I like. Anyway, I can try changing internal volume and a higher tuning frequency. There is so much more adjustment before I give up on what is likely the best output for deep bass I've had in a 12". It would be nice to have it all. |
#13 |
#14 | |
If you use lots of EQ on a sealed box to bring up the low end, you're missing the whole point of alignment/sizing. You select the driver and build the box size so that the natural roll off gives you the response you want.
I was so much older then, I'm younger than that now. |
#15 | |
The reason mentioned a 1000w amp do it can handle the EQ.
I thought about it once, but then thought again. |
#16 |
If this is indeed for automotive use then I'd say run a few sweeps in your car, measure, and find out where the peaks and nulls are. Something tells me this is an artifact of the cabin of your car and cabinet tuning and not of the driver.
Lets also get straight that not all cars sound good with a ported box. Example... my friend wanted a ported box in his van, cabin gain made this optimally loaded driver/cab combo sound like *** (literally farted) so I designed a T-line that was slightly larger than the ported but offered better detail and control. Additionally we measured the resonances of the inside of the van and found that if we tuned the cabinet to "optimal" tuning the van had huge bumps in response from 20-45 hz resulting in a boomy fart like sound (typical booming kids type single note sounds). Once we built the T-line and tuned it to 35hz rather than the 25 or so before it changed things drastically. Not all boxes are created equal in car audio without doubt, as no two cars cabins are the same you kind of have to consider more 'environment" than science at this point. One thing I've learned about car audio applications is that Optimal tuning for that driver may not be optimal in car due to a very low tuning frequency, this due to cabin gain artifacts in general. Most "KIDS" feel lower tuning will get them better low end and bragging rights (dude it's tuned to 18Hz), when all it gets them is muddy sound without detail... or Quarter panel farts!! My opinion is that your cabinet in car is creating the same artifact in your current cabinet within the confines of your cars system. Try, if your willing, to build a slightly higher tuned box 35-40hz, try a t-line even. Remember even if you tune with a natural 6-12dB rolloff below port tuning the cars gain will make up for the rolloff most times. Once again I doubt the TC sounds driver is at fault here...
What was that?... I can't hear you I have a line array filling my ears. |
#17 | |
As stated, this ported alignment is repacing a ported alignment. If the other ported subs had the detail then its not the fact that this sub is ported that is the issue. I also stated that I brought the sub into my house yesterday all day for use indoors to assess it in a non-car environment. I guess many people only read the first post and not the follow up which is ok. I am changing the internal volume and tuning today to see where it lands me. 1.85 cubes ported to 26.5 decreases group delay and may improve things. I will also try a sealed box regardless so I know first hand what the differences are other than a drop of 8db drop at 30hz. I think things work both ways. People read things on the internet and go with ported or sealed based on what they read and rarely try another alignment. I tried ported and sealed on the two prior subs and ported was better for me both times. Now how many sealed fans try a ported box? I doubt many do because they believe sealed sounds better but they dont know first hand. I will post pics of the sealed box I will build for it today. Any suggestions for size or should I just go .9 cubes net as WINisd says is a .707 alignment? Last edited by SpinMonster; 28th May 2012 at 06:53 PM. |
#18 |
Spin do you have DSP in the car?
Sealed does sound less boomy because the rolloff better compliments the cabin gain, but if you had a ported setup that sound good and only swapped boxes/subs then you're right, you should be able to get it to sound the way you want. Last edited by m R g S r; 28th May 2012 at 07:00 PM. |
#19 |
Sounds like you need to do some sweeps of the driver/box/car combo to figure out where the mud is. My guess is that it's tuned too high. That driver dosen't need the port output to go low. I'd try stuffing a towel in the port and then run a sweep. (or play some tunes)
cheers revb. |
#20 | |
Yes, there were numerous ported boxes in this truck and all but an alpine 15 ported sounded better. Run a ported simulation on this 12" and compare the group delay to a ported 10" Scan Speak L26roy. Maybe it has to be run sealed for SQ............so........ I built a sealed box today for it. Its already glued together. Tomorrow I router the edges and put it in the truck. It has a 1.2 cube net internal volume which I will change by adding blocks in to run it between .9 cubes to 1.2 leaving no stone unturned. I expect a big drop in ultimate SPL output at 25hz (7db) and it will be faster as the group delay drops big time. It models 44HZ as its -3db point using the specs DATAbass measured for the driver....not so impressive....and -11.2 at the point my current box is -3db at (23hz). If I was willing to give up the low end SPL, then I could have just used a 106grm cone 10" to start with. I am open to the possibility that this sub has to be used sealed for SQ so I'm trying it but that mindset could have been used for every other ported sub I've had in my truck. I didnt have to use them sealed because they didnt have one note bass in a ported application. If you want loud deep bass, the TC is built for it and wins all the trophys. If it has to go in a sealed box to not have one note bass and loses the SPL and 7db at 25hz, I could have had that for 1/2 the money. Last edited by SpinMonster; 29th May 2012 at 12:18 AM. |
| TC Sounds Projects? | Pano | Subwoofers | 5 | 28th July 2010 11:26 AM |
| TC Sounds (aka Audiopulse) LMT TC-9 (predecessor to LMS) | DavidJanszen | Swap Meet | 1 | 5th June 2008 05:32 PM |
| New TC Sounds Subs (pics) | Patrick Bateman | Subwoofers | 2 | 9th January 2007 08:28 PM |
| TC Sounds | herm | Subwoofers | 3 | 14th May 2006 12:48 PM |
| TC Sounds TC2+ subwoofer | tktran | Subwoofers | 16 | 20th May 2004 01:36 PM |
