Old 5th May 2012, 12:22 PM   #11
forr is offline forr  France
forr's Avatar
I propose the following reasoning.
Let's start with the well known formula
F = (Bl) * I <==> (Bl) = F / I
Then (Bl) can be considered as the ratio of the driving force, F, to the current in the voice coil, I.
If between different configurations, the current through the circuit is maintained at a constant value I :
Single driver
Fsingle = (Bl)single * I
(Bl)single = Fsingle / I
Series Isobarik
Current I goes through each voice coil, each motor gives the same force as in the single driver case, and both forces add :
Fser = Fsingle * 2
(Bl)ser = Fser / I = (Fsingle * 2) / I = (Fsingle / I) * 2 = (Bl)single * 2
Parallel Isobarik
Current I is equally split to I/2 into each coil, the force of each motor is halved compared to the single driver case, and both forces add :
Fpar = (Fsingle / 2) * 2 = Fsingle
(Bl)par = Fsingle / I
In this configuration, for the same current, the force is the same as for the single driver case.
Hence the wire can be considered as having the same length l with its resistance halved compared to the single driver case.
Edit : similar thinking to Line Array but I did not read his post before sending this one.
Old 5th May 2012, 12:36 PM   #12
So for LF enclosure design the only thing relevant
happening - besides voltage sensitivity changing -
is Vas halves for the compound driver, regardless
if wiring series or parallel.
Qes and Qms remain unchanged.
One could even short circuit one of the two driver's
voice coils and connect only one of them to the amp.
Having one coil disconnected and open would rise Qes.
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 26th September 2012, 05:18 AM   #13
Zoodle is offline Zoodle  Australia
Will two Isobariced drivers have a different QTS compared with a single driver? Also can one use lowish QTS drivers in Isobaric configuration (Eg .3)?
Old 26th September 2012, 09:22 PM   #14
No. Yes.
(Qts remains the same, because Qes and Qms stay the same - see post #12.)
Old 2nd January 2013, 07:20 PM   #15
Patrick Bateman's Avatar
This paper on BL seems to imply that low-BL drivers have worse impulse response than high BL drivers.
This is rather interesting, as I've long noted that high BL prosound drivers tend to sound 'tight', but I'd assumed this was purely a function of their response shape. Someone with a better grasp of the relation between impulse response and frequency response could likely provide a better commentary than I can.
http://www.extra.research.philips.co...s/aar05pu3.pdf
"Because Bl influences the transient response of normal
drivers and low-Bl drivers in particular, a transient response analysis is presented next. In [24] the response to a sinusoid which is switched on at t 0 was calculated. Those results showed that the medium- and high-Bl driver systems rapidly converge to their steady-state response, while this is not generally the case for low-Bl drivers. This can also be seen by calculating the impulse response.
Either way, it's a good lunch time read.
Old 3rd January 2013, 12:26 PM   #16
Shadydave's Avatar
Could it be the case that a series isobaric configuration, with each driver having the full current flow, they would experience higher I^2*R losses and thus go into thermal compression sooner?
It would seem to me that the parallel setup may have advantages in power handling.
This of course is only an issue in some circumstances, but I have always believed that THD is markedly reduced and SQ improved by running LF speaker systems at less than half their power capability and also much less than Xmax.
Dave
Footnote: In working with dual linear alternator systems, the series vs. parallel question seems to always end up with no clear winner, so this is one reason I pose this question.
<---My Transmission Lines from a prior life
Top one Tweeter...Bottom one definitely a Sub
Old 3rd January 2013, 03:33 PM   #17
ßart West-VL.'s Avatar
A Watt is a Watt...
Be it in series or parallel, result is the same.
The only difference is, for series the Voltage needs to be higher, parallel lower.
Series the current will be lower. parallel→higher current.
Result: the same power. So it will generate the same heat. (do the maths)
Old 3rd January 2013, 07:27 PM   #18
Parallel connection is preferred over series connection for isobaric drivers, especially in cases where there is significant pressure on the "inner" driver such as smaller than optimum enclosures or ported enclosures - basically, any situation where one driver experiences different forces than the other.
Shadydave, it alo applies to linear actuators driving uncoupled loads which may differ in weight / resistance, such as amp racks that are heavier on one side then the other...
Old 3rd January 2013, 08:35 PM   #19
Shadydave's Avatar
Default A Pascal is a Pascal
Originally Posted by ßart West-VL. View Post
A Watt is a Watt...
I knew there was a good explanation why it didn't really matter.
Thank You
Dave
PS
it alo(sic) applies to linear actuators driving uncoupled loads which may differ in weight / resistance, such as amp racks that are heavier on one side then the other...
OK, just wondering why one may have linear actuators on an amp rack
Last edited by Shadydave; 3rd January 2013 at 08:51 PM. Reason: Just wanted to check my signature explanation
Old 4th January 2013, 03:40 AM   #20
Originally Posted by Shadydave View Post
... PS OK, just wondering why one may have linear actuators on an amp rack
To make it tilt up, of course. (I'm talking about competition car audio installations.)
Series or Parallel / Bridge or Parallel? Tenson Chip Amps 2 3rd October 2011 12:53 AM
winISD calcs: parallel vs series-parallel sadams Multi-Way 1 20th February 2011 07:45 PM
Series-Parallel Or Parallel-Series shaan Full Range 43 13th December 2009 04:10 AM
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 24 10th May 2009 03:24 AM
What would you do? series/parallel MtnBob Multi-Way 13 14th April 2005 10:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
