My next subwoofer project, opinions needed! - diyAudio
Old 28th April 2012, 08:58 PM   #1
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Default My next subwoofer project, opinions needed!
Hey guys.
I'm in the process of deciding what I want to do for my next subwoofer project.
I have some space to work with now that I've mostly completed my media room. I've got about 14' x 18' of room to work with.
I've built out one of the walls away from the concrete foundation because I've been contemplating an infinite baffle array with a pair of Fi IB3 18's. I've ordered the amplifier that I plan to drive them with (a Behringer EP2000) and now that I'm to the point where I want to pull the trigger on a couple of drivers, I'm not sure.
The IB318's mounted in infinite baffle would be cool, however my last subwoofer project was a couple of T-TQWT using some old Peerless 831759 and I love them.
My question is this. Do you guys think that a pair of Fi IB318 drivers mounted in infinite baffle would outperform something like, a pair of TC Sounds Epic 12" in a T-TQWT?
Size and WAF are not an issue.
Old 28th April 2012, 10:32 PM   #2
revboden's Avatar
OutPerform in what way? The IB option would generally have better SQ but the T-TQWT would generally be louder. What are your preferences?
Old 29th April 2012, 01:19 PM   #3
DrDyna's Avatar
Hm, outperform, I guess I mean output, but I hadn't really considered that one might just simply sound better than the other.
The other facet of this issue is a nasty bass cancellation that this room has which I've been able to finagle by moving my t-tqwt subs closer to the listening position, where the IB drivers would be mounted in the wall and that's where they'd have to stay.
I guess in the end, my order of importance is like this:
1.) Low frequency extension. (20 cycles give or take a couple.)
2.) Cleanliness / low distortion.
3.) Lots of output.
I am open to other suggestions besides the two I mentioned. I'm looking to spend somewhere around $200-250 for each driver. Really, I'd build anything, even something like a DTS-10 if I could get the drivers for the right price. SDX10s, TC Sounds, Lab12's....I'm open to anything.
Old 29th April 2012, 02:09 PM   #4
tb46 is offline tb46  United States
Hi DrDyna,
Petter Persson's Kraken 212 seems to fit the bill (and save you money). Build one (or two), and use your T-TQWTs with the Kraken(s) in the Geddes multiple sub approach (to equalize the room response). All well tested, and well documented here on diyaudio. :-)
Oliver
Old 29th April 2012, 04:42 PM   #5
DrDyna's Avatar
Originally Posted by tb46 View Post
Hi DrDyna,
Nice, 135 db @ 20 cycles, that's pretty impressive. I'll have to read through this thread, I hadn't seen it before.
Thanks for pointing it out!
Old 29th April 2012, 10:29 PM   #6
revboden's Avatar
Two Kraken 212's would be... Moving. Literally
Old 30th April 2012, 11:28 AM   #7
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi all,
FYI:
b
Old 30th April 2012, 01:13 PM   #8
DrDyna's Avatar
Originally Posted by bjorno View Post
Hi all,
FYI:
b
Awesome B.
So, if I place them near to each other, the Kraken should be polarity inverted?
I have my T-TQWT placed closer (and a little behind) the listening area right now because when it's placed at the front of the room, I get a nasty cancellation right around the center of the room which is just large enough to envelop the couch. I figured I needed either a larger tv (so I could move the couch farther back and out of the null) some bass traps at the rear wall, or just move the subs into the null area, which seems to have worked well. It does cause some directionality, it's pretty easy to hear that the subs are close by, so for now I've simply got their level turned down a little.
The position I was thinking for the Krakens would be left and right flat against the walls with the mouth section facing out (the latest image of the Kraken in that thread has the mouth open at the end of the line instead of at the side of the end like a dts-10)
I was thinking that the Kraken might help the room null because it sits pretty far out into the room (the mouth would almost be 15-20% out from the front wall), but I haven't had a chance to build a TH yet so I'm not sure how they behave as far as positioning is concerned.
No doubt though, that this would cause some time alignment issues and I would have to rethink the positioning of the Peerless T-TQWT again.
I'm still considering the IB318s though, the IB alignment looks very nice. Perhaps not as powerful as the TH, but that's the beauty of the IB is...if you want more, you just start sawing more holes in the wall and stick in more drivers!
Thanks very much B, I'll be studying those images carefully.
A subwoofer project, help needed... Dxvideo Subwoofers 0 2nd March 2010 02:32 PM
Opinions Wanted on Dual 12" Subwoofer Project Sithlord2007 Subwoofers 20 19th September 2008 04:46 AM
Subwoofer Crossover Advice / Opinions Cambo82 Subwoofers 4 16th March 2006 10:13 PM
Help needed for high power coffee table subwoofer project Sixthofmay Subwoofers 26 6th July 2004 12:31 AM
Subwoofer opinions needed! chr Subwoofers 4 17th November 2002 09:44 PM
Copyright 1999-2017 diyAudio
