Old 28th April 2012, 06:13 PM   #1
djkiwi is offline djkiwi  United States
Default DIY 50 Hertz and below Sub
Hi Guys, I'd like to build a pair of 15 inch subwoofers and would be grateful for some guidance.
My main speakers are a pair of TAD 2402 speakers biamped. The bass drivers are TAD 15 inch 1601c driven with bridged crown K1 amps. In other words I am getting very impressive mid bass. My room is very well treated. The sub will be 90% movies and 10%. The room is fairly small at 18 x 14 ft although can accommodate fairly large subs but not huge. I am happy to EQ. The sub will be driven with a Crown K1 amp.
I'm looking at a sub that excels in the sub 50hertz range so am looking for a sub that can kick hard below this. I'm interested in quality solid deep bass that can match the quality of the bass from my mains. I am happy to build a sub with 2 x 15 inch drivers if that would improve the objective to achieve the deepest most solid bass.
So advice on:
1. The brand and model number of a driver
2. Any box plans somebody would care to share.
Thanks in advance
DJ
Old 28th April 2012, 07:21 PM   #2
How big are we talking? Sub 20hz horns get very very large. Think Danley DTS 10 and lab 12 horn on here and kranken 212...all very large all respectable output to 20hz...
Old 28th April 2012, 08:38 PM   #3
Every one who have built the Kraken 212 has comment it as rock solid and very deep
Old 28th April 2012, 08:47 PM   #4
I wrote Kranken not Kraken My bad.
If a 20hz horn Is too big then you need to build a low tuned bass reflex or sealed
Horn loaded would be my choice!
Old 28th April 2012, 09:22 PM   #5
Hi Guys, thanks for the responses. I am familiar with the Danley DTS 10 and it is a monster. I could get away with it if I put it up against the side wall. Petter, I'd never heard of the Kraken but it looks impressive as well. Then I see the Lab12 as well which looks similar. I do prefer horn bass. Has anybody heard the Kraken, LAB12 and Danley DTS 10 and have an opinion on the strengths and weaknesses of each one?
Cheers
DJ
Old 28th April 2012, 10:01 PM   #6
Hi Petter. I have read through the entire Kraken thread now and you have inspired me to build a Kraken. It's a great piece of work.
I see you discussed the Lab12 there as well. I do like the size of the 112 as it is easier to move around the room plus I would have room for more than one. The question is how many Kraken 112s would it take to equal the performance of a single 212?
DJ
Old 29th April 2012, 06:44 AM   #7
Nice! The output of two Kraken 112 is the same as one 212 but you will not benefit the
advantage of the push pull driver configuration to reduce distorsion. Othetwise, the horn
dimensions are the same but half.
Old 29th April 2012, 03:03 PM   #8
Thanks Petter. I see your point. I will ask any questions on the Kraken thread now.
Cheers
DJ
Old 29th April 2012, 05:02 PM   #9
If you were tight on size you could try an iso tapped pipe...Art did so recently with good results using dirt cheap drivers.
Height would be the largest dimm...
Old 30th April 2012, 03:54 AM   #10
The "Totem" (named due to the 5 stereo cabinets grafted together to make it) sub could be laid down, and the exit could be out the "skinny" end without affecting the response.
It really does fill in the 20-40 response, but as it is a shop speaker mostly playing the radio, generally not much content down that low.
When some sub 40 content is present in the music, it is quite obvious even in the wood shop, the Totem stands in the electronics room.
Art
DIY KSA-50 Complete Amp john65b Swap Meet 6 22nd July 2011 05:11 PM
Help!...it hertz crick Full Range 9 2nd July 2007 08:34 PM
Zero hertz jaberwocky6669 Multi-Way 36 16th June 2007 03:59 AM
Amazing $1.50 DIY interconnects! Sarchi Everything Else 29 10th July 2006 05:07 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
