I found it using "kraken" in the search function of DIYAUDIO, but I did read a lot before I realized that it was the thread "build your own 2x12..."
+1...perhaps we should have a mod put "Kraken" in the thread title.
You're right.I believe it wasn't named that for a while after the thread was started (if my memory serves correctly)
If there is no Thread with Kraken in the title, then where does none start?in a thread where people obviously know!
Google usually makes for better search results that our "search" function.
This Google function is one I rarely use, but I was stumped this time, so resorted to it.
See above ...
Pick a thread, any thread where someone mentions it, then ask!
- Subwoofers
- DIY 50 Hertz and below Sub
