Bang for the buck 18"/15" subs? - diyAudio
Old 27th April 2012, 06:35 PM   #1
Default Bang for the buck 18"/15" subs?
Looking for some better drivers for my BR boxes. Kappalites are on sale for $200 and this 18" is under $100, what other bargains are out there?
Old 28th April 2012, 03:40 AM   #2
Desired frequency response?
The Dayton doesn't have much xmax...
Old 28th April 2012, 04:41 AM   #3
I have a Kappalite 3015lf and this is pretty great for music, around 200 liter box
jee.
Old 28th April 2012, 10:33 AM   #4
Scott L is online now Scott L  United States
Default The bargain you asked for
Greetings,
In my opinion based on 39 years experience, this woofer model from PE is about the best bang-for-the buck performer:
Dayton Audio ST385-8 15" Series II Woofer 295-130
One driver per channel adaquate for medium sized rooms, but 2 per channel
in a reaction-canceling enclosure would be almost world class.
Old 29th April 2012, 02:46 PM   #5
Default I have 700 watts to throw at it.
The 3015LF is my first choice but I am exploring cheaper options.
This will be used for live sound and DJ work so I only need to cover 40-100hz.
I can build another box but already have a 200 liter box and a 175 box with $25 bargain basement 15"s loaded in them (not really subwoofers).
Sensitivity: 98dB (W/M)
Impedance: 8ohm
Re: 7.2ohm
Le: 1.37mH
Frequency response:
32Hz~2KHz
Fs: 32Hz
Qts: 0.41
Qes: 0.475
Qms: 2.9
Vas: 232 liters
Xmax: 3.75mm
About anything will be an improvement.
Old 11th May 2012, 04:39 PM   #6
Ordered the Kappalite before another round of neo price increases. (I should have bought four back when they were $160)
Not sure what type of problems I will create if I run my pair of low budget boxes @250watts each and the 3015fl @500watts but I will have fun finding out.
Old 14th June 2012, 12:55 AM   #7
Found some 15" MCM specials for $37 each.
http://www.mcmelectronics.com/conten...ts/55-2963.pdf
The Datasheet says...
Sensitivity: 97dB (W/M)
Impedance: 8ohm
Re: 7.2ohm
Le: 1.619mH
Frequency response: 32Hz~3KHz
Fs: 32Hz
Qts: 0.39
Qes: 0.437
Qms: 3.3
Vas: 286 liters
Xmax: 7.5mm (3.75 in description)?
Could be a bargain if it has a true 7.5mm of travel.
Old 14th June 2012, 07:40 PM   #8
djk is offline djk
djk's Avatar
"Could be a bargain if it has a true 7.5mm of travel. "
Divide that by two, it's a misprint. The catalog description says:
* Sensitivity: 97dB (W/M)
* Impedance: 8ohm
* Re: 7.2ohm
* Le: 1.619mH
* Frequency response: 32Hz~3KHz
* Fs: 32Hz
* Qts: 0.39
* Qes: 0.437
* Qms: 3.3
* Vas: 286 liters
* Xmax: 3.75mm
* Overall frame diameter: 15.28"
* Required cutout: 13.94"
* Mounting depth: 6.30"
Candidates for the Darwin Award should not read this author.
Old 21st June 2012, 04:42 AM   #9
Default Oh Yea 7.5mm of travel on that driver!
Just got a E-mail from MCM, the datasheet from the manufacturer is correct and website is being updated.
Old 21st June 2012, 05:32 AM   #10
ByronInPortland's Avatar
Isn't anyone going to ask what is the volume of Mr Doom's cabinets and what the port is tuned to? And are you willing to re-tune the port if necessary?
The woofer's potential is irrelevant. All that matters is how it will perform in your cabinets with your crossover. The folks at Madisound and Parts Express and probably other vendors will be able to help you select a woofer that best suits your needs. You would be lucky if the best woofer for your cabinets was also on sale.
Good luck.
(1) 15" sub (2) 15" PR's 18.7 hz build NewWorldAudio Subwoofers 9 30th August 2011 03:23 AM
the "do you have expericen with this thread" DAC, best bang for the buck? murphythecat8 Digital Line Level 6 27th April 2011 06:36 PM
WTB 15" or 18" high qt. drivers homemade Swap Meet 13 14th June 2010 07:15 PM
looking for the most "bang for buck" classD kit demogorgon Class D 4 23rd March 2006 06:57 PM
Dayton 8" bang for buck question Mos Fetish Multi-Way 0 4th July 2003 07:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
