#21 |
Hi Scruffyht,
Can't see why not. Main difference would be the location of the terminus (vent). Regards,
Oliver |
#22 |
[QUOTE=J. L.;2985834..If I ever feel ambitious, I'll model my 18" Avalance drivers in a T-TQWT enclosure and see what they can do. I'll bet the pair of them will be more than sufficient for most movies in a home-theater...[/QUOTE]
Hi Joe, Thank you for posting the links..Nice readings..I've made a HR template using the Ascendant Avalanche18 inch driver and more: b
#23 | |
As you might guess, most of the time my subs are loafing. I am impressed though with the T-TQWT design, even though my aging ears don't hear much at 12Hz, even though it seems the drivers can easily get that low in the simulation. (and you only simulated it with one driver) I can tell you for sure you can feel it. I can share with you that I had to weatherstrip the closet doors in my theater, as they vibrated in their door frames at about 17Hz so much they were a distraction. As I said earlier, these designs are more than sufficient for our home theaters. (most people do not know what they are missing) thanks again. I'll be curious to see what can be done with the 10" height requirement the original post requires. Joe L. Last edited by J. L.; 16th April 2012 at 07:50 PM. |
#24 |
Hi bjorno,
Your Hornresp simulations in Post #22 have Vtc and Atc values. Is this intentional? Regards,
Oliver |
#25 | |
Yes,I calculated with a double thickness of the internal divider, i.e. 2 x 18 mm Ply for the sturdiness of the enclosure baffle and to gain some driver clearance too. b
#26 |
#27 |
Any chance you guys can help with the dimensions of the box ... would be appreciated? ... dual or single tang band drivers like what permo used?
Thanks |
#28 |
Hi Scruffyht,
I've been trying to find the time to look at this with Hornresp and AkAbak. When I use Hornresp I can arrive at a smoother response with the port slightly out of the corner (venting to the top in the middle between the two drivers), and a slightly longer tube path. The result looks reasonable. Trying to enter this into AkAbak I have not had any success duplicating the Hornresp result. I get the SPL boost you would expect from a corner, but do not get the smooth extended response I get in Hornresp (which results from shortening the L34 distance, i.e.: moving the port closer to the middle of the drivers). The shape of the SPL curve in AkAbak looks a lot like the 2pi response for the same enclosure in AkAbak while the response in Hornresp is a lot "cleaner" in 0.5pi than in 2pi. Anyway, I'll attach a Hornresp input screen, and the 2pi/0.5pi SPL comparison. I'm not sure when I'll find the time to improve on the modelling in AkAbak; but from this simulation, and hopefully bjorno's input, we should be able to arrive at a folding/stuffing that should work for you. The dimensions always change a little when you transfer from paper to wood. I don't mind doing the drawing, but I want to wait to see what bjorno has to say to this simulation. Bye the way, do you have a supplier for this driver? Regards,
Oliver Last edited by tb46; 18th April 2012 at 01:12 AM. |
#29 |
Hi Oliver ... thanks for all your efforts ... yes ... we do have a Canadian distributor
#30 | |
The cure is to remove a foot from the closed end or stuff the first foot with very dense damping material like dense Rockwool 1-2lb/ft^3 =16-24kg/m^3. This could be simulated in AKAbak too by changing the waveguide sections into Ducts and invoke the 'damping material' switches. b
| New Home Theatre Sub | dark_avenger | Subwoofers | 11 | 29th December 2007 02:28 AM |
| Home Theatre | bhg41088 | Multi-Way | 4 | 16th August 2004 01:32 PM |
| aleph theatre? | cowanrg | Pass Labs | 123 | 18th January 2004 11:55 AM |
