Tapped Horn TH-121 build - Page 7 - diyAudio
Old 11th July 2012, 02:05 PM   #61
ZivkoF is offline ZivkoF  Slovenia
Originally Posted by djlivex View Post
So can I build this with 15 mm Marine plywood if that's lighter, sound reflectors I can build with Arauco ply which all braces in my Tuba I am building are Arauco and very lightweight. Also Can I use a different Faital instead of the 1500XL. I need it to go down to 30Hz +/- 3dB indoors, plan to build 4 X 1819 subs, thanks!
Hi djlivex,
yes you can build TH_1819 with 15mm Marine plywood and I have simulated some different Faital 18-inch and also Faital 15-inch drivers and results were great to go down to 25Hz +/- 3dB outdoors, so indoors the results will be even much better.
Old 11th July 2012, 03:01 PM   #62
djlivex is offline djlivex  United States
Great! Which 15" Faital (18" Faital expensive) I'll be happy with 30Hz outdoors, what's the average SPL 30-100Hz? I plan on 4 subs initially. Just curious! Thanks!
Old 11th July 2012, 04:49 PM   #63
Look at US Speakers for Faital 15FH500 and 18FH500, with average SPL 98dB 30-100Hz outdoors.
Old 11th July 2012, 04:54 PM   #64
Ok thanks! I know those drivers, which Faital can I use to get an average SPL of 105dB 1W/1M outdoors???THANKS!
Old 11th July 2012, 05:53 PM   #65
Faital 15FH500 is great if you want low you loose on high SPL, cant have boath at 2,0 Pi (outdoors) 2,83V @ 1m; 20Hz-88,68dB; 25Hz-94,45dB; 30Hz-96,99dB at 0,5 Pi (corner indoors) 2,83V @ 1m; 20Hz-101,51dB; 25Hz-107,0dB, 30Hz-108,7dB which are very good results.
Old 12th July 2012, 12:24 AM   #66
Would 4 per side 15FH500 or 18FH500 achieve 105 average +/- 3dB out doors or no can do? I like the simplicity in the build but indoors looks very nice, I maybe asking too much!
Old 12th July 2012, 04:59 AM   #67
Yes 105dB is the minimum for 4 per side which can achieve out doors, if they are colocated up to 110dB. Site for SPL calculation.
Peak SPL Calculator
Old 12th July 2012, 11:20 AM   #68
That's great when I finish my current project I will start on these. I am currently building a small 3 way with subs for up to 300 venues dance system. I have been looking around for a nice Tapped Horn to build on here including the Xoc or 35Hz Tapped Horn but this cuts the cake for low output, this may shake my furniture out of my house! LOL
Old 14th July 2012, 11:57 AM   #69
Hi ZivkoF, what tops are those you have pictures in previous post? Are they DIY and what HF horn you're using, driver just curious. Will you be using this as 3-way for PA use and/or playback? Thanks!
Old 14th July 2012, 02:04 PM   #70
HF is Neo Compression Driver BMS4540ND with 114 dB sensitivity @ 1W/1m
Volvotreter 20Hz Tapped Horn build (pics) RadiantNRG Subwoofers 77 27th July 2015 05:18 AM
Horn Build using a tapped horn as a frame?? 3GGG Multi-Way 1 17th January 2012 11:52 PM
Dayton SD315-88 Tapped Horn Build killa12222 Subwoofers 11 15th June 2011 05:46 PM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
Copyright 1999-2017 diyAudio
