#51 |
Thanks Epa, this is the first time that I can compare sound of FLH to sound of TH, my two CV AB-36C are good high sensitivity but are no match <35 Hz to singel TH_1819, all are corner loaded. It is still in burning period and driver takes some time tu burn in. Some more photos. |
#52 |
Isn't it amazing how 2 different sub enclosures with similar volumes (roughly 18ft3 externally) can perform alot differently!
#53 |
Force is strong in him...............
#54 |
Welcome to the dark side!
#55 |
Tapped Horn TH_1819 now I have it a little more than 14 days and has already played bass so confidently, precisely and smoothly, without any distortion and high second and third harmonics. I do not know if someone already did this in Slovenia (Tapped Horn) woofer, so it might be the first one!
#56 |
No it's not the first one
Nice build
#57 |
#58 |
Those are monsters alright, I like it but at 176 lbs without the driver whew! That's heavy I am still looking for a nice sounding subs and kick horn for playback, something that won't sound monotone. I have heard Danleys TH15 and they are wonderful to the ears and low distortion compared to some folded horn designs. I am currently building 4 Tuba 24's loaded with double 4 ohm BP102 for general DJ duties. But I want to build a nice TH that will reach 30Hz on cheaper 18" FaitalPro drivers 4 subs easy to build like yours but I need a kick horn on top of them for playback dance system with a Turbo TSE-111 top probably. Can these monsters be built light (120 lbs manageable with a neo 18 Faital) like 15mm BB and put lightening holes on all braces??? Those 18XL1500 are out of my budget but can break my piggy bank!
#59 | |
I was looking first to build with MARINE plywood (9 ply) but the ordering time took to long so went for 18mm BB. The 9 ply marine plywood is also 18mm but very lite, so TH_1819 weight without the driver + braces + sound reflectors inside would be some 120 lbs the dimension is not so small so you need some wood as the horn path is 15 feet long. 49,21 inch high x 31,50 inch deep x 22,83 inch wide. It will reach -3dB 22 Hz and -10dB 18 Hz outdoors at 2Pi 2,83V@1m I have xo set at 110Hz so it has a lot of punch.
#60 |
So can I build this with 15 mm Marine plywood if that's lighter, sound reflectors I can build with Arauco ply which all braces in my Tuba I am building are Arauco and very lightweight. Also Can I use a different Faital instead of the 1500XL. I need it to go down to 30Hz +/- 3dB indoors, plan to build 4 X 1819 subs, thanks!
| Horn Build using a tapped horn as a frame?? | 3GGG | Multi-Way | 1 | 17th January 2012 11:52 PM |
| Dayton SD315-88 Tapped Horn Build | killa12222 | Subwoofers | 11 | 15th June 2011 05:46 PM |
| Volvotreter 20Hz Tapped Horn build (pics) | RadiantNRG | Subwoofers | 60 | 12th March 2011 07:18 PM |
| Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background | layertone | Subwoofers | 15 | 23rd January 2010 05:12 AM |
| Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background | layertone | Full Range | 2 | 23rd December 2009 12:51 AM |
