Tapped Horn TH-121 build
New 8 x Pulsar 10.1 speakers for Dolby Atmos, DTS:X and Auro 3D are ready, just waiting drivers from factory to be delivered - have some delay!
Wow!! Congrats! They look impressive! 🙂
Can you share the drivers/horns and xo points please? In the past I had something like this, but there was something about the sound when I had the little horn mounted coaxial like yours. I remember I chose to rest it on top of the big horn. Can you tell me something about this, if you tested maybe.
Yes no problem. Drivers (with NEO magnets) are mid is Faital 10PR300 (8 ohm), HF is Faital HF108 (8 ohm) and HF horn is Faital LTH102 - xo is at 1.350 Hz/12 dB oct. internal wire is Jantzen 1,3mm2 for HF and 2,5mm2 for mid driver and signal.
