Tapped Horn TH-121 build
Old 29th October 2012, 04:01 PM   #121
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by epa View Post
post 112 right pic ,is that a seperate hf unit?
That is a Danley Sound Labs DSL SM60F "full range" molded Synergy horn.
Art
Old 29th October 2012, 04:45 PM   #122
epa is offline epa  Netherlands
couldn't quite see the scale of it .
intresting speaker.
so hf driver in the midlle,then 2 holes for each of the 8"driver and 4 hh holes at the end?
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 29th October 2012, 05:02 PM   #123
ZivkoF is offline ZivkoF  Slovenia
Art
Hi weltersys,
Yes it is DSL SM60F, I have heard and seen this speaker 2 weeks ago in my city where I took the photo we had Hi-Fi fair and it was playing in one room. I was expecting more from this speaker in the terms of the sound it was good but not to throw me out from my shoes - that is happening only with my Hi/Mid and Low TH suwoofers at home......
Old 29th October 2012, 05:26 PM   #124
weltersys's Avatar
intresting speaker.
Four outer holes are bass reflex ports, four middle bandpass holes for the two outer speakers, four little center bandpass holes for the coax cone, center hole for the coax HF driver.
Very coherent single source constant directivity dispersion, though the conical expansion is not the most sensitive type of horn.
Old 29th October 2012, 05:49 PM   #125
Tom Danley is offline Tom Danley  United States
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
Hi
It is as Art identifies and an implementation of a Synergy Horn as built as Fig#7 here;
Patent US20090136072 - Sound reproduction with improved performance characteristics - Google Patents
The SM-60f is a 3 way Synergy Horn system which also has a pair of 8” woofers feeding the horn (not shown in Fig#7).
The idea is that you are adding these three frequency ranges at dimensions that permit the wavelengths to add coherently like two close coupled subwoofers do except in the throat of a constant directivty horn which governs the radiation pattern.
The passive crossover accounts for the front to back time delay caused by the driver placement and the result is there is no normal crossover phase shift and so what one measures / hears appears to be from a single driver. With any of the Synergy horns, you can walk up to one and even put your head in the mouth and you cannot hear any hint there is more than one source somewhere in front of you.
Our company doesn’t advertise very much but the speakers are edging closer to you, two video’s from Denmark.
Use headphones for the first one if you have them, you can hear the difference between a single acoustic source per side and an array of sources per side.
It doesn’t show in a response curve but you can hear it even with a camcorder.
Danley Sound Labs SM80 vs. d&b Q7 - YouTube
Danley Sound Labs Jericho on Ledreborg 2012 - YouTube
Best,
Tom Danley
Company Facebook page
http://www.facebook.com/DanleySoundLabs?ref=ts
Bring back mst3k and futurama
Old 1st December 2014, 10:41 PM   #126
$$Maan is offline $$Maan  Denmark
So fun, this thread ended with a post from the master himself:-)
I'm from Denmark and I heard good about that job:-) Actually the boxes were for sale one year after for some reason.
My reason for posting is this:
I'm modelling a 21" tapped horn for a wagon, I'm modelling in free field.
In my newest model I'm not only modelling the air below the wagon, but also the expansion all the way around it up the sides, that extends the lowcut downwards.
I'm not sure how it's best to place the driver, one consideration is a mouth a bit like a tham18 facing downwards another is to have the driver parallel to the ground with the magnet facing straight down. Any opinions on this?
The driver I happen to have by coincidence is beyma 21sw1600. Sorry if I'm a bit offtopic, but this thread appears to be dead anyway, nevertheless subject still is 21" tapped horn, but NO Danley clone.
This is a nonprofit diy cargo-bike project, pedalpower!
Old 2nd December 2014, 02:31 PM   #127
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
I thought vertical was the best position to prevent cone sag?
Old 2nd December 2014, 02:35 PM   #128
BP1Fanatic's Avatar
Old 26th January 2016, 11:13 AM   #129
parsleybasilkale is offline parsleybasilkale
Hi Zivkof. Really effective design and a simple build. I wonder if you had any thoughts about them being used outside of your intense home theatre setting. Do they remain efficient enough to warrant the size for playing out at events? It would be amazing to be able to play to 22hz regularly with ability for upper xover point between 80 & 110hz.
Is the best choice of driver for enough efficiency to play out still 1600xl?
I have precision devices 1850 and rcf lf18n401 already but the xl1600 is a reasonable price here in the UK.
It would be interesting to try the BL and FS monsters that are Turbomax as they are built locally to me.
I've also had great use out of Oberton drivers, a Bulgarian company who have recently appointed a UK distributor.
The cabinet size suits me very well for groundstacking as my tops (community tfr34a) are 85cm deep and 63cm wide at the front.
Old 26th January 2016, 12:57 PM   #130
I've got a few high powered amps to try them with...
Void infinite 8v2 and 7v2, matrix 7000mf (3.5k @ 4ohms) and sae pxm1450.
Tapped Horn TH-121 buildHide this!Advertise here!
Volvotreter 20Hz Tapped Horn build (pics) RadiantNRG Subwoofers 83 23rd July 2017 10:06 PM
Horn Build using a tapped horn as a frame?? 3GGG Multi-Way 1 17th January 2012 11:52 PM
Dayton SD315-88 Tapped Horn Build killa12222 Subwoofers 11 15th June 2011 05:46 PM
Lab 12 Tapped Horn, Ron's Austin II, T-Horn, CNC Photo Background layertone Subwoofers 15 23rd January 2010 05:12 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
