Old 31st March 2012, 11:28 PM   #11
tb46 is offline tb46  United States
Hi mdocod,
By definition the throat chamber attaches through the Ap1/Lpt port to the horn @ S2. If you introduce anything but a very short L12 you are modeling a tapped horn with an offset tap, in other words the port does not attach to S1.
Try setting L12 to .01, and add the old L12 to L23. See if that makes a difference.
Oliver
Old 1st April 2012, 12:06 AM   #12
mdocod is offline mdocod  United States
Send a message via AIM to mdocod
Hi Oliver,
You're right, I have that "messed up."
I went back and tried those changes- not much difference to the result. (small differences like this don't usually cause monumental changes so that's a blessing)
The more accurate simulation shows me that the result is still going to be a far worse sub than the original design was with the sealed enclosure
Eric
Old 5th April 2012, 03:19 AM   #13
abcdmku is offline abcdmku  United States
It's built. and at 40 Hz it is a beast, filled the entire basement with solid bass [with only 50 watts]. Something I noticed with this design, is that when I would walk away from the horn it would not phase in and out. Where my vented enclosure would. I just ordered the iNUKE NU3000DSP when it comes in I will give it one watt and do a spl test when I get the time.
Old 5th April 2012, 04:50 AM   #14
kctess5 is offline kctess5  United States
Got any pictures? I'd be interested to see those graphs once you get them. Id be interested to see a front loaded horn with the rear chamber vented, like a lab horn except vented instead of sealed enclosure as opposed to this tapped horn type vented enclosure. Interesting idea, could work out
Old 5th April 2012, 11:52 AM   #15
I'll get some pictures when I do the spl test, I think I'm going to do that later today.
Old 5th April 2012, 01:31 PM   #16
epa is offline epa  Netherlands
nice work ,maybe ur on to something
one good thing about music ,when it hit you feel no pain.
so hit me with music
Horn experts - Please help to determine optimal throat size for low-mid horn pk Multi-Way 9 19th August 2012 06:29 PM
Compact budget subwoofer: vented or TL/Horn? mvangel Subwoofers 21 5th February 2009 11:21 AM
HT bass horn with vented rear chamber paulspencer Subwoofers 2 26th February 2006 06:02 PM
Copyright ©1999-2013 diyAudio
