Old 26th September 2012, 05:14 PM   #51
Veke76 is offline Veke76  Finland
Originally Posted by Veke76 View Post
I'll make a cable with R1=10kohm R2=10kohm ratio will be 2:1. I'll report back here if I get this right.
With new cables gain ends up 11 o'clock position to play at balance. Ratio is actually 1:1!! Sub input takes some volts but I believe at full power it will overdrive/damage. Strangely the balance is what I wanted so this is some sort of progress.
Eminence Lab 15 and Hypex DS8.0 is ok combination now that i found out how to tweak out more oomph.
Old 6th November 2012, 10:24 AM   #52
The acoustic problems in the room were so annoying so I bought Anti-Mode 8033 S-II.
It took automatically six freq sweeps...it lasted for ages.
The sound is bit quiet now. I think those peaks are now flattened and I can hear some new sounds which were hidden under.
The input signal to antimode clipped with 1:1 cables so I'll try 1:10 cables or I'll make new cables with adjustable ratio.
Old 3rd December 2012, 12:12 PM   #53
Default Eminence LAB 15 + Hypex DS8.0 sealed box
Here are current freq sweeps of my room with LAB 15 + Anti-Mode. Difference with AM ON/OFF and one sweep with higher volume.
File Type: png Screenshot from 2012-12-03 14:59:33.png (75.8 KB, 135 views)
Old 4th December 2012, 01:38 PM   #54
Freq sweeps how loud it will go. Sweeps approached maximum with red line.
File Type: png Screenshot from 2012-12-04 16:29:07.png (72.3 KB, 118 views)
Old 14th December 2012, 09:38 AM   #55
Default Lab 15 + alternative enclosures
Now that I've have my sealed sub working I've got interested in TH and TQWP enclosures. How an upgrade to these enclosures might work. Basically I need 100 dB@1W and max spl 125 dB. Is it even possible with Lab 15? Enclosure could be 60x60x60cm cube or tall 50x50x120cm for example. What I measured from sealed Lab 15 I've got some corner room gain. So hopefully freq will extend low as 20 Hz in room.
40Hz TH
3015lf TH @ 35-40hz but only 20" deep help
15" kicker l7 30hz box design help !!
Single sheet TH challenge
THAM15 - a compact 15" tapped horn
Cubo15
Old 14th December 2012, 01:37 PM   #56
tb46 is offline tb46  United States
Hi Veke76,
To get down to 20Hz you'll need a large TH (I ended up with some simulations @ 340/390 L that looked promising), maybe something along the lines suggested by bjorno would work (MLTL), see: Posts #7/#9 here: Lab 15 design suggestions for HT use?
Oliver
Old 14th December 2012, 03:16 PM   #57
Thanks I forgot that thread existed. I'll post there what I had in mind
Old 14th December 2012, 04:36 PM   #58
Well I need F3 30-35Hz design. Usually with WinISD I try to hit F15 @ 20Hz. Seems that room gain adds up that much so that equals F3 point (in room).
Eminence Lab 12 Business running123 Subwoofers 3 12th December 2011 09:40 PM
Eminence Lab 12 subwoofers CZ Eddie Swap Meet 0 5th July 2011 04:02 AM
best encl. volume for Eminence Lab 12 in a sealed sub? Bill poster Subwoofers 9 22nd November 2010 10:10 PM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
Eminence Lab 12 + Amp + Box combo metaverse Car Audio 57 7th January 2009 11:42 PM
Copyright ©1999-2013 diyAudio
