Eminence LAB 15 + Hypex DS8.0 sealed box - Page 4 - diyAudio
Old 4th April 2012, 06:12 AM   #31
Veke76 is offline Veke76  Finland
Default Eminence LAB 15 + Hypex DS8.0 sealed box
For HT use and 20Hz I would go vented enclosure. At sealed enclosure F12=25Hz and max spl @20Hz=110dB(in room). A few designs from eminence -> http://www.eminence.com/pdf/LAB_15_cab.pdf
Old 4th April 2012, 01:48 PM   #32
tb46 is offline tb46  United States
Hi vinodk,
T-QWP = tapped quarter wave pipe
T-TQWP = tapped tapered quarter wave pipe
These enclosure forms have been advocated in this forum by bjorno, and seem to result in home speakers of high quality. If you use the search you should be able to find any number of examples. Here is one:
Tang Band Tang Band W8Q-1071F 8 X 12 box reccomendation
Oliver
Old 4th April 2012, 03:55 PM   #33
Hi Veke 76,
A TH would work nicely for HT, if you have the room for it, about 400L_net minium. Much better low end than a BR.
Oliver
Old 4th April 2012, 04:11 PM   #34
Hi Oliver
LAB15 Large Deep Bass Design is also ok @300L vented
regards,
Vesa
Old 4th April 2012, 09:40 PM   #35
Hi Veke 76,
Here is a Hornresp comparison between a TH and the "Large Deep Bass Design", both with the same internal volume (Hornresp may exaggerate the peaks):
Oliver
Old 5th April 2012, 06:00 AM   #36
With Large Deep Bass Design port air velocity and group delay becomes issue. It peaks 26m/s@22Hz. It should stay below 17m/s. Group delay 56ms@22Hz. It should stay below 18ms.
Any similar problems with TH?
Old 5th April 2012, 02:19 PM   #37
Hi Veke 76,
I think particle velocity is where the real advantage of the TH over the BR comes in:
Oliver
Old 10th April 2012, 07:22 AM   #38
My 67L sealed enclosure and highpass@12Hz and lowpass@80Hz will give nice sim output down to 18Hz in room and 110dB@20Hz in room. That's enough for me.
Old 11th April 2012, 02:11 AM   #39
Hi Veke 76,
And your design will make it so much easier to fit multiple subwoofers in the same room. Will you be taking measurements when you're done?
Oliver
Old 11th April 2012, 06:05 AM   #40
Yes I'll post here my measurements when I'm done.
best encl. volume for Eminence Lab 12 in a sealed sub? Bill poster Subwoofers 23 1st November 2016 12:17 AM
Eminence Lab 12 Business running123 Subwoofers 3 12th December 2011 09:40 PM
Eminence Lab 12 subwoofers CZ Eddie Swap Meet 0 5th July 2011 04:02 AM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
Eminence Lab 12 + Amp + Box combo metaverse Car Audio 57 7th January 2009 11:42 PM
Copyright 1999-2017 diyAudio
