Eminence LAB 15 + Hypex DS8.0 sealed box
Old 23rd March 2012, 02:53 PM   #21
tb46 is offline tb46  United States
Hi Veke76,
That looks nice. I would add cleats in all the corners, and account for their volume as well as the volume of the compressed filling material, and the back of the woofer.
Oliver
Old 23rd March 2012, 03:23 PM   #22
Veke76 is offline Veke76  Finland
Default Eminence LAB 15 + Hypex DS8.0 sealed box
Bracing needs little bit more work. Chamber behind driver is bigger and needs more support. I made a mistake and the driver comes deeper than I thought.
The actual volume is about 57L and acoustic volume is 68L. I will stuff it 24g/L of damping material which is alot and it will increase the volume plus 20% to 68L. Some may disagree with this but I want same output as in the sim of WinISD. Next choice is to make 500x500x500mm cube which would work even without stuffing. Actually I modelled it at first.
http://www.nousaine.com/pdfs/Box%20Stuffing.pdf has some info on stuffing subwoofers. On sealed box 24g/L is ok but with bass reflex maybe 12g/L.
Old 28th March 2012, 06:16 AM   #23
Ok. Now I'm thinking this might be more easier to make. 500x500x500mm cube. Actual volume 68L or maybe more with stuffing.
Old 28th March 2012, 07:39 PM   #24
Hi Veke76,
Yes, this would be easier to build. I would add at least one cross-brace on the panel separating the woofer chamber from the amplifer chamber, slightly offset from the middle.
Oliver
Old 30th March 2012, 07:06 AM   #25
Hi.
I have a little bit of a problem now with materials. Maybe some expert in subwoofer box building will read this...
I asked prices from a carpenter and it seems a box from 26mm glued birch board is pretty expensive to make. I could get 19mm MDF box much cheaper.
Atleast there is two problems with MDF. One is finishing the surface so that it doesn't look ugly. Second is that it might resonate more and will the baffle hold togeather.
The driver will be placed a few millimeters deeper in baffle. Joints in box will be made with lamello.
Maybe a white or black paint job on surface and the baffle could be double?
Old 30th March 2012, 01:41 PM   #26
Dag Johansen is offline Dag Johansen  Norway
Im not sure what you mean by "finishing", but it is easier to get a nice finish from mdf.
For hifi i think 19mm is a bit on the lean side, schould be at least 22mm.
Lamello is fine, use a lot of white glue (you have Cascol in Finland?)
A small tip: after aplying glue on mdf, put the bits together and wait a few minutes before putting pressure on the joints, this way you get a stronger joint because glue penetrate the flat hard layer.
Dag
Old 31st March 2012, 06:25 PM   #27
I decided to go for the 19mm MDF and double baffle. My "workshop" didn't have big enough space and tools for this project so the carpenter will assemble the enclosure. I just do sanding, paint job and installation. I'll have it in 2 weeks and then I get to do my work on it.
Old 3rd April 2012, 02:54 PM   #28
vinodk is offline vinodk  United States
I am also looking at Lab 15 for my DIY sub in a 2600cu.ft. dedicated HT room. I am looking to place the driver in passive sealed enclosure with lot of polyfill. Wondering what the volume of enclosure should be so that I get decent extension & output down to 20hz.
Old 4th April 2012, 12:39 AM   #29
Hi vinodk,
Do you already have the LAB15s? If not, I would advise to look at other drivers, e.g.: the Epic 12" that PE sells outperforms the LAB15 in a sealed HT application. Or go for a different enclosure, e.g.: a T-QWP looks promising for the LAB15
Oliver
Old 4th April 2012, 03:59 AM   #30
Pardon my ignorance, what is T-QWP?
Eminence LAB 15 + Hypex DS8.0 sealed boxHide this!Advertise here!
best encl. volume for Eminence Lab 12 in a sealed sub? Bill poster Subwoofers 25 2nd February 2018 12:10 AM
Eminence Lab 12 Business running123 Subwoofers 3 12th December 2011 09:40 PM
Eminence Lab 12 subwoofers CZ Eddie Swap Meet 0 5th July 2011 04:02 AM
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 10:15 PM
Eminence Lab 12 + Amp + Box combo metaverse Car Audio 57 7th January 2009 11:42 PM
