PK Sound CX800: 95% efficient??
Old 19th March 2012, 09:00 AM   #11
CRESCENDO is offline CRESCENDO  United States
"An amplifier may have 90% efficiency, but a speaker may not."
Ah, that makes more sense
"What about power compression?"
I know this needs to be factored in for real world numbers. I assumed they posted "calculated" numbers, but still felt them to be a little....'fluffed'....or too good to be true.
"Did you know that a degree in marketing allows you to change the laws of physics by a factor of 10:1 to your advantage?"
Lol, I don't know wether to laugh or to go get a degree in physics!
"The x-max is at best a P-P value."
Also makes much more sense! Thanks for your investigation tactics.
Is there a formula(s) to figure out the maximum efficiency at 30hz being on the order of 96dB/W/1M from a net vol of ~14cu ft?
Old 19th March 2012, 11:05 AM   #12
djk is offline djk
djk's Avatar
"Is there a formula(s) to figure out the maximum efficiency at 30hz being on the order of 96dB/W/1M from a net vol of ~14cu ft?"
Simple.
Use the base figures in post #2 (after DB Keele) for 2nd, 4th, or 6th order. Find the ratio of the cabinet sizes. Take the log of that, and the x10, the answer is in dB difference.
14/2=7
7log=0.845
x10=8.45dB
Double/half the box size = 3dB.
2log=0.301
x10=3dB
One octave, dropping from 40hz to 20hz = 8x volume (for the same efficiency)!!!
87.56dB + 8.45dB = 96.01dB
Candidates for the Darwin Award should not read this author.
Old 19th March 2012, 11:58 AM   #13
Simple is nice. Awesome. Thank you.
Another question for the book o' basics (since it seems too many manufacturers have different approaches): what's the proper way to calculate/determine the spec: +/- 3dB? Using hornresp, bassbox, or any freq resp plot.
Old 19th March 2012, 03:43 PM   #14
epa is offline epa  Netherlands
Originally Posted by djk View Post
http://www.eighteensound.it/renderPdf.aspx?pid=288
You run the numbers and see if I am correct.
sorry missed that.
btw the 9000 models easyer in a th too.+ a tad "cheaper"
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 19th March 2012, 10:18 PM   #15
Has it been determined whether the low corner drops with BR and/or BP designs, or not? Last I read, most said, "no" regarding tapped horns, but there were still discrepancies.
Old 20th March 2012, 08:35 AM   #16
the low corner doesnt drop,just the directivety changes(depending on how you place the subs)
only in flh the low corner drops becuase of the extended horn buble in front of the horn.
in th the lenght of the driver to mouth section grows a bit with the mouths coupling,resulting in a minor change in the th system.
. hr driver db
Old 27th March 2012, 12:22 AM   #17
Jeremy Bridge is offline Jeremy Bridge  Canada
Hey everyone, glad to hear some chit chat about our new subwoofers they have been working out really great for us =]
Thought I would drop by and try to answer some questions.
#1 Obviously the enclosure is not 95% efficient (I wish) but the amplifier is Class D and capable of that efficiency. That efficiency does drop as output and heat increase, such is life.
#2 No where does it say the SPL measurement was taken at 30hz or free field, it does say that is how the frequency repsonse was measured. The cabinet was measured ground plane as is typical with most subwoofer measurements in our industry.
If you look around you will see this figure is well within what many manufacturers are showing. Meyer HP700 = 139db. http://www.meyersound.com/pdf/products/concert_series/700-hp_ds.pdf
It's funny because I had a long chat with some people from Meyer at the Pro Light & Sound in Frankfurt last week about spec sheets and how they are interpreted by our industry. In fact with thier new 1100-LFC they say they will not be releasing specs and posts like this are the prime reason.
They full believe, as do I, that to evaluate a product you need to hear it and use it. Then you can make up your mind for yourself.
If you love our product, great, if you like something else that's cool too there are many great companies in our industry =]
Jeremy Bridge P.Eng.
PK Sound
Old 27th March 2012, 10:55 AM   #18
djk is offline djk
djk's Avatar
The bovine excrement is getting hip deep.
From the data sheet: the response was FREE FIELD RESPONSE
Publish 100W/10M 2Pi data with no processing.
Old 27th March 2012, 03:34 PM   #19
tb46 is offline tb46  United States
Hi Jeremy Bridge,
Post #17: "...95% efficient (I wish) but the amplifier is Class D and capable of that efficiency. That efficiency does drop as output and heat increase..."
I realize the difficulties coming from advertising your products in the real world, but it would be nice if you could post a few graphs, e.g.: efficiency v. power out, or, efficiency at different power levels v. frequency, and the usual: THD+N V. power out, power out v. frequency.
As to SPL measurements, I like the Danley Sound Labs method of 100W/10m/2Pi too. That should be the industry standard for PA purposes, additionally an actual maximum long term SPL would be nice. :-)
Oliver
Old 28th March 2012, 04:55 AM   #20
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
DSL actually publishes 28.3v/10m/GP, regardless of the nominal impedance of the system.
Dan
PK Sound CX800: 95% efficient??Hide this!Advertise here!
What is Simplest and Best 6L6 PP circuit? (PK) zxx123 Tubes / Valves 33 26th March 2013 03:06 PM
FS: Black Gate STD and PK Kuka Swap Meet 13 27th November 2011 09:28 AM
PCM54HP vs. PCM 63 pk- no winner! AnthonyAsh Digital Source 10 4th August 2005 07:50 PM
miracle: all solid state oszillator with 160 ps pk-pk jitter capslock Digital Source 3 17th September 2004 01:49 PM
1 efficient 12" or 2 (far) less efficient 10"s? beady Car Audio 4 8th August 2004 05:55 AM
