TinyHorn
Have a 12PS100 laying around and decided to do something with it. I worked in Hornresp and akabak today and came up with this Akabak script. Let me know what you think. I did draw it out in Sketchup as well
Copy below this line
|TH-TinyHorn
|TundraLTD
|Network node numbers for this tapped horn system:
| 0-Voltage-1
| -Chamber-5-Driver-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------
|8-Duct-9-Duct-10-Duct-11-Duct-12-Duct-13-Duct-14-Duct-15-Duct-16-Duct-17-Duct-18-Duct-19-Duct-20-Duct-21-Duct-22-Duct-23-Duct-24-Duct-25-Duct-26-Duct-27-Duct-28-Duct-29-Duct-30-Duct-31-Duct-32-Duct-33-Duct-34-Duct-35-Radiator
Def_Const | Data for Vtc Chamber
Vtc = 1897.00e-6; |Throat chamber volume (cc)
Atc = 531.00e-4; |Throat chamber cross-sectional area (sq cm)
Sd = 531.00e-4; |Diaphragm area (sq cm)
Ltc = Vtc / Atc;
Def_Driver '12PS100'
Sd=531.00cm2
Bl=23.77Tm
Cms=1.17E-04m/N
Rms=7.93Ns/m
fs=43.9994Hz
Le=2.00mH
Re=5.30ohm
ExpoLe=1
System 'TH_TinyHorn'
Driver Def='12PS100'
Node=1=0=5=33
Filter 'HP1' |Highpass 24dB Butterworth
fo=43Hz vo=1
{b4=1;
a4=1; a3=2.613126; a2=3.414214; a1=2.613126; a0=1; }
Filter 'LP1' |Lowpass 24dB Butterworth
fo=104Hz vo=1
{b0=1;
Duct 'Throat chamber' Node=5=9 SD={Atc} Len={Ltc} visc=20
Duct 'D1' Node=8=9 HD=34.5cm WD=2.450cm Len=15.95cm visc=50
Duct 'D2' Node=9=10 HD=34.5cm WD=4.590cm Len=31.40cm visc=20
Duct 'D3' Node=10=11 HD=34.5cm WD=5.220cm Len=1.060cm visc=1
Duct 'D4' Node=11=12 HD=34.5cm WD=5.090cm Len=1.600cm visc=1
Duct 'D5' Node=12=13 HD=34.5cm WD=4.600cm Len=1.200cm visc=1
Duct 'D6' Node=13=14 HD=34.5cm WD=8.060cm Len=44.97cm visc=1
Duct 'D7' Node=14=15 HD=34.5cm WD=9.120cm Len=1.854cm visc=1
Duct 'D8' Node=15=16 HD=34.5cm WD=8.850cm Len=2.850cm visc=1
Duct 'D9' Node=16=17 HD=34.5cm WD=8.030cm Len=2.160cm visc=1
Duct 'D10' Node=17=18 HD=34.5cm WD=10.74cm Len=34.93cm visc=1
Duct 'D11' Node=18=19 HD=34.5cm WD=12.17cm Len=2.472cm visc=1
Duct 'D12' Node=19=20 HD=34.5cm WD=11.80cm Len=3.798cm visc=1
Duct 'D13' Node=20=21 HD=34.5cm WD=12.32cm Len=7.188cm visc=1
Duct 'D14' Node=21=22 HD=34.5cm WD=11.95cm Len=3.847cm visc=1
Duct 'D15' Node=22=23 HD=34.5cm WD=10.88cm Len=2.921cm visc=1
Duct 'D16' Node=23=24 HD=34.5cm WD=12.51cm Len=21.13cm visc=1
Duct 'D17' Node=24=25 HD=34.5cm WD=14.16cm Len=2.869cm visc=1
Duct 'D18' Node=25=26 HD=34.5cm WD=13.73cm Len=4.422cm visc=1
Duct 'D19' Node=26=27 HD=34.5cm WD=12.51cm Len=3.357cm visc=1
Duct 'D20' Node=27=28 HD=34.5cm WD=13.29cm Len=10.12cm visc=1
Duct 'D21' Node=28=29 HD=34.5cm WD=16.50cm Len=4.409cm visc=1
Duct 'D22' Node=29=30 HD=34.5cm WD=19.36cm Len=5.643cm visc=1
Duct 'D23' Node=30=31 HD=34.5cm WD=18.25cm Len=3.663cm visc=1
Duct 'D24' Node=31=32 HD=34.5cm WD=22.70cm Len=14.79cm visc=1
Duct 'D25' Node=32=33 HD=34.5cm WD=28.04cm Len=17.77cm visc=20
Duct 'D26' Node=33=34 HD=34.5cm WD=33.02cm Len=0.001cm visc=1
Duct 'D27' Node=34=35 HD=34.5cm WD=33.02cm Len=1.800cm visc=1
Radiator 'Radiator' Def='D19' Node=35
External dimms? Response looks good for a low midbass / subwoofer for portable rig that won't be playing much dub!
In light of recent talk with cone correction plates, I like the fact that the pressure on the cone is more evenly spread instead of having half the cone open past the s2 point...
Several friends that make their living in the industry had issue with it. I used to work design/install and still work on special projects for them when needed. We didn't make it a big discussion and I don't want to burn my friends and contacts I have. If you would like a copy of the plans and have no intention of using it for profit I'm still willing to share it by request. Hope that is a simple enough explanation
Hi!
i have got this chassis lying around and have been searching diyAudio for a Speaker to build with it. The Tiny-Horn sounds pretty awesome, so it would be great if you could share the plans with me. This will only be for my private joy and for advancing my woodworking skills 😉.
THX
themmm
