Hard to make choices with DIY subwoofer
Old 20th April 2012, 05:30 PM   #41
diystuff is offline diystuff  Estonia
sorry i meant lower f3 and the minimum port length required seems to be less
Old 27th April 2012, 08:06 PM   #42
the lab12 driver has finally arrived!
Old 25th September 2012, 10:11 AM   #43
Let the building begin!
Old 25th September 2012, 10:49 AM   #44
DrNick is offline DrNick  United Kingdom
Excellent! I'll be following you in a month or so, so please post up how everything goes together!
Old 29th October 2012, 08:04 PM   #45
All the materials have finally been bought. The woodwork should be finished by wednesday. So my friend and I will be doing some serious building throughout this weekend
Old 3rd November 2012, 07:20 AM   #46
So we have started building in our ghetto workshop(friend's room). All the panels have been pre drilled and the bottom panel has been connected to he back panel. It's coming out very well, considering that we're using such simple methods of building.
Old 21st November 2012, 04:36 PM   #47
build is finally complete!!!!! well...sort of . We need to apply some paint to the box but that will happen later, sometime around summer. The sub itself is a beast, it weighs over 50 kg overall. The sound is incredibly loud yet deep and clean (now all i have to do is get monitors which can math this sub ). THe theoretical f3 of this thing was around 20 hz however i think the actual f3 is even lower as it can play 16 hz with quite a lot of power and no problems at all
Anyways, here are some more photos:
Old 17th March 2013, 09:32 AM   #48
Cool update!!
The subwoofer is thoroughly broken in and it sounds great! I'm still stuck with some shitty sony bookshelves which I will burn once I get myself a pair of Monitor Audio Bronze BX2 bookshelves . Anyways, on the bottom of the sub you can see two grey foam pads. These are Sonic Design damping feet: SD damping feet for loudspeakers
they work like a charm, parents aren't whining about the house shaking that much anymore and i feel the imaging/dispersion of the bass in my room has improved. This is important because i have a vaulted roof which messes up the sound dispersion in my room. Soon I will paint the inside of the ports, in black of course, and after my summer vacations from school I will paint the whole sub.
How do you think i should go about painting the sub? I wanted to have a wood finish but i dont know how to use wood stain and i dont wanna risk anything. Is it possible to slap on some veneer at this stage?
Old 16th October 2013, 05:04 PM   #49
Default Subwoofer Painted!
It was a hard job to paint the subwoofer, because my childish ways made me unable to be patient enough to wait to paint the sub enclosure AND THEN mount the driver and all. I actually completed painting in the end of August.
Anyway, my Swedish friend and I managed to do it. We took the sub out and covered the driver with plastic film and tape so the poor weather wouldn't get to it. And we started painting with rollers :P .
I bought the indoor wood paint so it took a **** load time and it wasn't drying fast enough outdoors. So i brought it inside and continued. Overall, I put on 3 layers of paint and 2 layers of primer.
The primer was made by mixing wood glue with water.
Firstly, using auto body filler I filled in the gaps and the screws and 'levelled' the surface so it would seem smooth. I brushed primer all over the sub, then I sanded the surfaces of the sub, after added a coat of brown paint with the roller and sanded once more. This process was repeated once more after the first coat of paint had dried. And the final coat of paint was just added onto the existing coat of paint without any sanding or priming.
So here is how it looks like!
Old 16th October 2013, 06:59 PM   #50
MemX is offline MemX  United Kingdom
Well done on finishing it
Listening to it is far more fun than painting it, so I understand your impatience! lol
Hard to make choices with DIY subwooferHide this!Advertise here!
help needed with HT DIY sub choices boogs Subwoofers 22 19th November 2005 02:50 AM
HARD DRIVE DIY = using multiple FLASH USB DRIVEs ?? JinMTVT Everything Else 6 29th October 2005 11:09 PM
how hard is it to make a PCB? theChris Everything Else 0 3rd June 2003 08:40 AM
Home Theater Combo - choices choices smithsonga Multi-Way 1 2nd April 2003 05:11 AM
Copyright ©1999-2017 diyAudio
