Xoc1 6F TH
Xoc1 6F TH
Old 8th March 2012, 09:33 PM   #11
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Hi Kornylike
Checked out your cutlist
Part 4 Which I guess is the top panel is short (Suggest 32-25/32")
Part 15 Top Back reflector is missing
Sheet 2 of the drawing is labelled with numbers for reference to cut list and angle sketch added.
Regards Xoc1
File Type: pdf 18in 30hz - 6 Fold TH Assy Inch Plus.PDF (127.2 KB, 128 views)
Old 8th March 2012, 10:10 PM   #12
kornnylike is offline kornnylike  United States
Xoc1
Thanks for the correction.
Old 9th March 2012, 12:03 PM   #13
scameron78 is offline scameron78  United States
how does this cab sim with similar drivers for your TH18 design Xoc1? how do the TH18 and this design compare?
Old 9th March 2012, 12:10 PM   #14
Xoc1's Avatar
This 6 Fold cab is bigger & lower than the TH18
Lots of info here on the basic design.
http://www.diyaudio.com/forums/subwo...ml#post2379086
Old 10th March 2012, 05:16 PM   #15
Default New cutlist
Updated 6f cutlist
Old 18th March 2012, 12:29 AM   #16
CRESCENDO is offline CRESCENDO  United States
Xoc1 6F TH
I was going to ask about the angles a couple weeks ago while cutting the test box panels, but didn't have internet access. Glad I figured it out (exc the sharp S1 angle piece - I waited on that one).
I got sick the other night, so I'm hoping to get my test box together very soon (after the weekend perhaps).
Kornnylike, are you building yours with the 2:1 compression baffle cut out or an open baffle?
Old 18th March 2012, 04:08 AM   #17
Crescendo
I will be using the 2:1 compression baffle cut out and I am also under the weather.
Flu with headache
Old 20th January 2013, 09:16 AM   #18
panjilaras is offline panjilaras  Indonesia
Kornny any updates? I have four 18nw100 for this design waiting for dry weather
Old 21st January 2013, 09:07 PM   #19
epa is offline epa  Netherlands
fyi
just simmed the 18nw100 .
it works great in this sub ,you can put a high pass at a verry low 25 hz with this driver.
i think cressendo bild a couple of them.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 21st January 2013, 11:49 PM   #20
Hi epa thanks for advice. Filters no problem I have loudspeaker management system
Hopefullly the rainy season will end soon and start making sawdust
Xoc1 6F THHide this!Advertise here!
An Odd Duck -- Gibson BR-6f Guitar Amp Teh Gav Instruments and Amps 5 5th February 2009 03:45 PM
