Help in identifying woofer
Old 27th February 2012, 05:48 AM   #1
Tyson82 is offline Tyson82  United States
Default Help in identifying woofer
Hey folks.
I was wondering if anyone had an idea on who the manufacturer of this woofer is? Unfortunately the only markings are the numbers on the nderside of the cone; 70815 014.
I need to get the specs on it if at all possible, so any help is much appreciated.
Old 28th February 2012, 03:04 AM   #2
Zero D is offline Zero D  United Kingdom
Hi, it looks a bit like an early EV = Electrovoice, But ?
Old 28th February 2012, 03:40 AM   #3
TundraLTD is offline TundraLTD  United States
TundraLTD's Avatar
what size is it?
Old 28th February 2012, 04:22 AM   #4
It's a 12". I don't know voice coil size or anything like that.
Old 28th February 2012, 07:31 AM   #5
djk is offline djk
R.I.P
djk's Avatar
That is an Electro-Voice Force12.
Candidates for the Darwin Award should not read this author.
Old 28th February 2012, 02:38 PM   #6
weltersys is offline weltersys  United States
weltersys's Avatar
I agree with DJK, looks like an OEM EV Force 12.
They were designed primarily as a musical instrument speaker, lots of built in harmonic distortion, and very little linear excursion.
Old 28th February 2012, 04:41 PM   #7
Cool, thanks guys. Looks like I came to the right forum!
Specs look like it should be fine for a floor monitor. Hate to see a decent woofer go unused.
Thanks again.
Old 28th February 2012, 09:13 PM   #8
weltersys's Avatar
Thanks again.
Tyson,
I used some Force 10 for PA with a HF horn coming in around 1500 Hz, to get the vocals to sound clean had to cross the 10 in at 500Hz.
I'd suggest selling it to a guitar player that will appreciate the distortion the speaker is designed to make.
Art
Old 28th February 2012, 09:44 PM   #9
R.I.P.
Hi, Yes, move it on to guitarist, guitar speakers don't make good monitors, rgds, sreten.
Old 28th February 2012, 09:49 PM   #10
The info provided by Weltersys says that is made for sound reinforcement systems, and EV made a line of PA cabs with these woofers if my research is correct.....
Help in identifying wooferHide this!Advertise here!
About the woofer:Passive Radiator or Double Woofer for Vetend kevinlin1013 Multi-Way 8 12th January 2011 06:13 PM
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 02:00 PM
Woofer replacement for Infinity Reference 2000.5 Woofer kchilaka Multi-Way 0 28th September 2010 05:11 AM
Identifying help placebo Full Range 0 31st July 2005 07:27 PM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
