I bought a new toy
I bought a Safety Speed Cut 6400 Vertical Panel Saw :rolleyes: same model they use in Home Depot stores. Just in time to do some serious Bass-cab building this summer. I'm open to letting people use it if you're in the area (Sacramento-ish) as long as you're responsible and probably have you sign a waiver or something
Home depot employees are not very accurate, it's all about the user like any tool. Yeah there are fine-tune adjustments. And lots of accessories to make things easier. I've got 2 table saws to do angle cuts etc. but this will make life a heck of allot easier cutting large of cabs out, I can't be sliding full sheets across a table saw anymore with a bad back
Yeah for the outside larger panels this would be great. Ripping across full sheets etc.
For inner boards I would still use the "set the fence and leave it set until you're done cutting every width cut on every inner board" method :D
Nice pickup!
How much? (if u dont mind)
And are you going to finally get started on those TH-18's with the B&C's? Or you going with a different box now?
Yeah I'm going to get that started, My old boss was going to build them but it has never happened (can't say I'm surprised) and I know I wont compromise on quality. With those drivers going at such a premium right now its either use them or get some $$$ out of them and I want to hear them!
