BASH 300S Blowing Fuses
Old 25th February 2012, 09:32 PM   #1
cheryl is offline cheryl  United States
Default BASH 300S Blowing Fuses
My BASH 300S started blowing fuses. I removed the amp and found a blown component. It is marked on the board as "R400" and on the component is "SCK 104". Research indicates that this is some type of thermistor -- but I have no idea what the specs are or where to get a replacement.
Does anyone know what the actual specs are on the component and where to get a new one?
Also, is this indicative of another problem in the amp that may be causing an over-current condition? I didn't see any other components that looked damaged. Or can these blow just from getting old and out of spec?
Thanks for any help,
Cheryl
Old 26th February 2012, 11:51 PM   #2
Dane is offline Dane
http://www.rihengqiang.com.cn/admin/...9171135515.pdf
10 ohm 4A
I'd rather a fuse blow than a thermister!
Try slo-blow fuse per spec.
Likely something else also wrong.
Old 26th February 2012, 11:58 PM   #3
The fuse did blow, and it is the proper fuse (3.15A, 250V, Slow-blow). So, I guess it is likely that something else is wrong in addition to the thermistor and the fuses blowing.
Thanks for the info!
Old 21st February 2017, 04:37 AM   #4
Bigmedina is offline Bigmedina  United States
Do you still have it
BASH 300S Blowing FusesHide this!Advertise here!
bash 300s digital amp ???? bostonswoop Subwoofers 10 24th June 2007 10:50 PM
Why are these fuses blowing Darin P-B Solid State 41 30th May 2005 10:56 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 02:16 AM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 12:16 PM
The Fuses Just Keep Blowing raffir Chip Amps 19 22nd June 2003 03:49 AM
