System Pictures & Description
Old 4th February 2014, 09:19 PM   #71
chrisb is offline chrisb
looks like it fires down into the mouth of horn - mounting access via the panel on which BASH amp is mounted?
frankly, I'd have done that part differently - just a personal thing, but I generally like to run outboard amps on subs
like my mind, this space intentionally blank
Old 4th February 2014, 10:54 PM   #72
dubwoofer is offline dubwoofer  United States
dubwoofer's Avatar
The woofer fires down into the throat section, it's not tapped. I mounted the amp on the panel for convenience. I have a second panel with terminals so I can use a better amp externally if I wanted to later. The plate amp is well sealed and doesn't cause any problems.
Old 5th February 2014, 04:24 PM   #73
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Originally Posted by mhouston View Post
Dubwoofer: which way does the driver go?
Tuba HT
Old 6th February 2014, 09:15 AM   #74
focal is offline focal  Germany
@Dubwoofer:
Thats correct size! Looks very good. How sound it?
Bye
Uwe
Old 6th February 2014, 01:39 PM   #75
BP1Fanatic's Avatar
Originally Posted by focal View Post
@Dubwoofer: Thats correct size!
Dubwoofer, which width did you build?
Old 6th February 2014, 06:02 PM   #76
dubwoofer's Avatar
I built it 24" wide... For the room it was going in I didn't need to go any wider.
@focal: The performance is very, very good. With the 200W amp it easily matched the output of my 500W eDesigns A5-350. It's not as musical as a lot of direct radiator subs I've heard but that's not a big issue for HT use. I get in-room response down to about 16Hz.
Old 6th February 2014, 06:56 PM   #77
BP1Fanatic's Avatar
That's strange to hear when the website shows the THT being responsive all the way out to 200hz.
Old 6th February 2014, 07:07 PM   #78
dubwoofer's Avatar
It didn't seem as articulate or "fast" as the A5-350, but that could be a limitation of the plate amp.
Old 6th February 2014, 08:03 PM   #79
BP1Fanatic's Avatar
What frequency do you have the low pass set?
Old 13th February 2014, 11:51 PM   #80
ReggieleeMorton is offline ReggieleeMorton  United States
ReggieleeMorton's Avatar
all very nice pics!
System Pictures & DescriptionHide this!Advertise here!
