System Pictures & Description
Old 28th May 2012, 06:28 PM   #21
Ivan Ingram is offline Ivan Ingram  Canada
I kept things simple, varnish on the veneer, gloss spray paint on the end caps.
Old 28th May 2012, 09:24 PM   #22
dustyschaffner is offline dustyschaffner  United States
My first time back here in quite some time. Thought I would post a quick pic of my brand new DIY subwoofer in here.
I built this sub because I built a new HT using commercial horns they were to be headed for a dumpster at a local theater. All they needed were new drivers in the bass bins, so I took them home and refurbished them. Since these are "W" horns, they didn't have a very deep-reaching response and I felt like they needed to be backed up by a dedicated subwoofer. This subwoofer was built specifically to hit the lowest lows in any movie, hit them loud, clean, and keep balance with the mains. The enclosure was a partitioned, dual-driver cabinet with each section having its own 4" flared port in the rear. It's all tuned to a whopping 23Hz using Eminence LAB-12 drivers. The drivers were wires in series for an 8ohm load to a SpeakOn jack on the back of the cab. This is where the enclosure will be connected to a Mackie M-1400i pro-audio amplifier, which is putting out 1000w@8ohm bridged. Now having the overrated amplifier was just for dynamic capability, but the subs are only rated for 800wrms combined. That just means I can't run full rms power. However, I should have no issues with dynamic or program power seeing as the peak power handling of the subs is 1600w.
The amps were also going to be tossed at the theater but I rescued and restored those as well. They had dirty switches and dead fans but they still had full-quality sound and no DC offset. Replaced the bad fans and put DeoxIt on the rear switches. Amps run like new!
Without further ado, pictures are here:
Eminence LAB-12 drivers (also in a temporary enclosure)
Boards cut and ready
Marking drivers
Half-assembled
Ports arrived from eBay. 4" Precision-Port flared kits
Marking ports
Cutting and installing ports
Installing input jack
Sealing the cab
Installing drivers
Finished product
The powerhouse (what you can see, hard to see the front side)
Sony BluRay
Xbox 360
Hitachi (I forget model) projector
Yamaha RX-V795 preamp (HT receiver)
Samson S-curve 215 for mains
Behringer FBQ1502 used as active crossover for subs (connected to Samson through link)
Mackie M-1400i for mains (the one on the top)
Mackie M-1400i bridged for subs (one on bottom)
Old 25th June 2012, 06:47 PM   #23
oLjud is offline oLjud  Sweden
THAM15 been benched!
Current DIY-project: FAST-speaker with scanspeak and faitalpro / Anaview amps with minidsp / 2way synergy horn
Old 1st July 2012, 02:09 AM   #24
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Nice!!!
Old 31st July 2012, 05:42 PM   #25
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Here's a few pics of mine, some under construction and sketches of my t-tqwt subs and my corner loaders. Peerless 831759s.
Some of the pics are from the room that I'm still in the process of building.
Old 2nd August 2012, 08:12 AM   #26
NWCgrad is offline NWCgrad  United States
I like your t-tqwt subs. Is this the desired goal on the video side of the reproduction chain?
Old 2nd August 2012, 12:39 PM   #27
DrDyna's Avatar
Yeah, there's going to be a projector in there eventually, I'm still using the tv from upstairs :P I'm also planning 2 Fi IB318's mounted in that wall, it's got space behind it.
Old 4th September 2012, 04:18 AM   #28
stan is offline stan
Default "DuoTrix", bolted on 2-way baffle on tritrix
Lots of foam.
Old 14th November 2012, 01:57 PM   #29
m R g S r is offline m R g S r  United States
The HT setup I finally completed in my apartment...
Surround:
Main L/R
Center stack:
Consists of..
Marantz SR5006 Receiver
Mini DSP for Subwoofer
QSC MX 1500 for Subwoofer
Sony BDP s590
Samsung 51" Plasma
Nintendo Wii
Verizon FIOS HD box
Speakers are all DIY:
Center: Zaph ZA5c
L/R: Curt Campbell Stentorians
Surrounds: Zaph ZA5
Subwoofer: 18" Dayton Ref. 225L Sealed box
Old 20th November 2012, 10:01 AM   #30
ahegyes is offline ahegyes  Romania
ahegyes's Avatar
In the link below you'll find the subwoofer I have built in this autumn.
Be aware - the content in translated via google traslate.
Google Translate
www.diy-audio.ro
System Pictures & DescriptionHide this!Advertise here!
