#11 | ||
@ weltersys
You posted whilst i was composing ![]() Quote:
![]() Quote:
If it did, what a difference it would make ![]() @ tb46 Hi, yes that's more or less it Just to get this off the ground, & for simplicity, i showed the drivers tuned box @ 90 degrees to the mouth & throat. This need not be the case, & could be angled.
#12 | |
b
#13 |
@ bjorno
Thanks a LOT
#14 |
@ bjorno
Hi & thanks again for the input & file, it's Really helped I've had a play with it & come up with this. I know it's far from perfect, but some of the graphs appear quite good, too me anyway. The hump @ 80Hz would be filtered out by a LPF @ the same f. I'ld appreciate comments from you & others.
#15 |
Hi Zero D,
Good to see your making progress. I'd like to point out that bjorno's Hornresp model is not tapped, and as such does not conform to your initial sketch. You may remember the "Crazy box design - Input please!" thread and Don Hills AkAbak model, that (plus the code by Cordraconis and Mavo, see Post #3 in this thread) may give you something to start from in AkAbak, Posts #36-40 : Crazy box design - Input please!. Regards,
Oliver |
#16 | |||
![]() Quote:
Naughty bjorno Quote:
As i'm still trying to get my head around HR, even though i've played with Akabak, i feel it's one more headache i don't need right now ![]() I would truly appreciate it someone could start me off with a HR file with my design, then i would find it easier to experiment more I would then post with further Sims using high power etc drivers for All to see.TIA |
#17 |
Hi Zero D,
I don't think this can be done in Hornresp, that's why I'm trying to provide you with links to Akabak code. I know that the code from "Crazy box" is not the same that you need, but there are lines in there you could use. Regards,
Oliver |
#18 | |||
![]() Quote:
I'll see if i can try to do something with it.Quote:
Thanks for being there & to Any others who could assist
| ported midranges | oublie | Multi-Way | 2 | 15th January 2011 01:47 PM |
| sealed vs. ported | sonu | Multi-Way | 25 | 9th May 2005 12:50 PM |
| TL Sub VS Ported Sub | dis | Subwoofers | 18 | 15th July 2004 08:46 PM |
| Woofer Towers, front-ported or rear-ported? | Goldenboy | Multi-Way | 6 | 15th June 2004 06:44 PM |
| Ported Encloser | HeyYha | Multi-Way | 4 | 5th April 2004 01:59 AM |
