I recently scored a pair of custom 18" BR cabs with the following internal dimensions:
32" H x 24 1/2" W x 17" D 2 x Ports: 6" diameter by 9" deep Need to find drivers that will work properly with these cabs. Any help would be greatly appreciated. Thanks, Theo |
#2 |
Quick easy way to sim would be WinSD
#3 |
www.mcmelectronics.com has a low-price driver. I used it to replace a JBL 2245H driver; the foam surround of which fell apart. This one has a durable paper accordion surround. A picture of the (small) refrigerator-size cabinet fitting this subwoofer is attached. This website also sells a 21'' driver.
#4 | |
Thanks, Theo |
#5 |
Please find the attached pdf which shows the selection of 18" drivers and their Thiele-Small parameters. I hope it is adequately legible.
#6 |
Didn't attach the first time; too much info? Here it is trimmed.
#7 |
The Order #s read from the top left to right and then bottom are: 55-2985, (21"), 55-2984 (18"), 55-2954 (18"), and 55-1875 (18"). Regards.
#8 |
Not sure what your budget is but the Sigma Pro-18A-2 would fit those cabinets like a glove. The cabinets are 7.5 cu.ft. tuned to 39 hz, the drivers will handle 300 watts with a hi-pass filter at 35 hz.
Eminence Sigma Pro-18A-2 18" Cast Frame Driver 290-427 |
#9 |
Nobody says you have to install an 18 inch driver in the hole. Why do you want to be stuck looking for a suitable 18 inch driver when you have a vast choice of drivers doing the same thing (and prolly better) at 15 inches?
A box that size sure makes a good sealed enclosure! Go for quality. Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), Klipschorn mixed-bass woofer w/param. EQ plus 1954 AR-1W or giant OB HiFi construction since 1956 |
#10 |
Theo,
What is the budget you are looking to stay in? That box size and tuning should work with a lot of 18" drivers out there. The ones you choose really depend on what performance level and price point you are looking for. I am particularly fond of RCF and B&C brand drivers, but they aren't all that cheap. Eric |
| Scaling up the SS15 for an 18" driver and other compact 18" designs | col | Subwoofers | 32 | 23rd January 2012 10:17 PM |
| DIY 18" PA subwoofer cabinet | CruiSE | Subwoofers | 17 | 7th June 2009 06:28 PM |
| Looking for Best driver for 5lt/.18 cu" front vent cabinet | mr_macgee | Full Range | 16 | 1st February 2008 03:36 PM |
| bass cabinet build two 18" speaker.. help | szgabor | Multi-Way | 3 | 7th August 2004 01:23 AM |
| Page generated in 0.10188 seconds (76.13% PHP - 23.87% MySQL) with 11 queries |
