#11 |
Thanks-I assumed it was, my first search found at Parts Express in thier pro section.
#12 |
Building horns looks like fun.
#13 |
Maybe, but they are more about SPL and hitting an extension that sound quality. You can do serious things with TH's for the size of any given driver, but they are big for the size of any given driver. If your amp has a buily in bass boost option the LAB12 in compact sealed box would work very well, if not a larger vented box is good. -3dB @ 40Hz and 30Hz, - 6db @ 31Hz and 23Hz, -10dB @ 24 Hz and 18Hz. The vented version has a lot more output capability very low down, and you'd probably need it to be able to hear the very lowest bass notes. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#14 | |
#15 |
My Eminence Lab 12 just arrived. I'm going to rule out the tapped horn, at least for now. Starting to think about box design.
| EL84 PP using 5K plate to plate primate OPT | jmillerdoc | Tubes / Valves | 5 | 9th March 2010 09:14 PM |
| 8" 'sub' and plate amp advice | 1234567890 | Subwoofers | 7 | 14th April 2007 12:36 PM |
| DIY Plate Amp --> Need the Plate!!! | gmikol | Parts | 4 | 17th February 2006 08:20 PM |
| Subwoofer Plate Amplifier Base Plate supplier? | jwells777 | Parts | 1 | 11th May 2003 07:40 AM |
| Page generated in 0.07714 seconds (74.76% PHP - 25.24% MySQL) with 11 queries |
