Old 30th January 2012, 09:02 AM   #1
Default Monacor SPA-10PA
Hi guys
Can the above Monacor model be used for a subwoofer? I have two of them lying around after a mis-buy and I was contemplating building a slim under-bed subwoofer. It will mainly be used for films so the bass doesn't have to be very loud or overwhelming. I just need it to be felt a little when sitting in the couch. It would be a good DIY project for me.
Here is a link to the specs:
SPA-10PA
Old 30th January 2012, 12:53 PM   #2
Hi, you can use it as a subwoofer, however even in a 2CF ported enlosure the F3 won't be much above 43Hz. Have tried tuning lower but response drops off. Make the box bigger and you can bring the tuning down while keeping a relatively flat reponse-what volume could you go to?
Old 30th January 2012, 02:51 PM   #3
The limiting factor is the height which has to be around 20 cm's. It has to be placed under a bed which gives it 28 cm's of clearance and I would like to place it on some feet so it doesn't have to rest directly on my concrete floor.
The box could probably be 100x150x22 cm's in outer dimensions if I can stretch it.
One of my main issues is that my room is in the basement which leaves me with concrete on 5 sides and a wooden ceiling. I don't require very low bass because that would just leave me with a lot of rumble and resonance and not much actual bass. I'd much rather go for precision at a bit higher frequencies.
Edit: My previous sub is/was a Cerwin Vega LW-12X which creates way too much rumble and not enough "punch".
Edit2: I have two of these drivers, so if they can be mounted in any way to create more SPL be my guest as to enlighten me. I have build Saturnus' Boominator, where the drivers are mounted back to back which increases their respective dB levels. Could something similar be done here to achieve MOAR BASS or well, more "punch".
Old 30th January 2012, 03:42 PM   #4
epa is offline epa  Netherlands
maybe a th or tqwtp.
maybe bjorno can help you
one good thing about music ,when it hit you feel no pain.
so hit me with music
Old 30th January 2012, 03:50 PM   #5
I saw it. I recognized technobabble. My head went . Can you elaborate a little bit for me?
Old 30th January 2012, 03:54 PM   #6
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
epa is right: Here is a suggestion:
b
Old 30th January 2012, 03:58 PM   #7
Okay, so with a horn design I could get it to have an SPL of 108 watts at 37 hertz? And the enclosure would need to have a volume of 78 liters. How about the design of the horn? I have seen some horn designs before, but I am unsure as to the angles I would have to use and so forth.
Old 30th January 2012, 04:18 PM   #8
Picarro: ..Okay, so with a horn design I could get it to have an SPL of 108 watts at 37 hertz?..
I don't know if a horn would achieve the numbers you've posted but a T-TQWT,definitively not a horn, would do this in a single folded enclosure.
.. How about the design of the horn? I have seen some, but I am unsure as to the angles I would have to use and so forth..
I've seen some too..thousands during at least 45 years..With various angles...
IMO, You're too quick and vague..(so forth)....
b
Old 30th January 2012, 04:38 PM   #9
b
Okay.. I will try to rephrase. I Googled your username and the term "TH" and I found a link about horns - therefore I assumed it was a horn you wanted me to build. I have no idea what a T-TQWT is, but I will Google it.
Old 30th January 2012, 05:01 PM   #10
Picarro, welcome to the wonderful world of quarter wave-I found it and am still trying to get my head round it-even working out what design is a horn, T-TQWT etc.
Bjorno, however, seems to know them inside out and can do what would take me a month in hornresp in a few minutes! I was still playing with hornresp and he's already got a nice model back for you! Follow his advice-follow mine and it's like the blind leading the near-sighted
Static on Right Channel Realistic SPA-100 d1ck Solid State 12 28th November 2011 04:16 AM
philips 2.1 spa 5300 subwoofer not working properly. it uses TDA8947J avinashpb Everything Else 2 18th November 2011 05:16 PM
Radford SPA-60 schematic wanted audiomatic Solid State 4 17th October 2010 06:01 PM
Roland SPA-240 amplifier molesz Solid State 1 26th November 2009 09:58 AM
running 11 speaker cables and 6 interconnects next to each other through a narrow spa rick57 Multi-Way 14 17th February 2006 11:35 PM
Page generated in 0.11548 seconds (80.38% PHP - 19.62% MySQL) with 11 queries
