#21 |
Agree with TheBaronGroog: You really need to adjust the width of your enclosure in order to allow for necessary volume consuming cross-bracings, that here should be incorporated overall..+ use a baffle thickness of at least 18 mm. I believe the 'gray filler material' is wasting volume(especially the ones in the corners that IMO have no function at all if not made of wood(enclosure stiffeners)) but could be replaced with a thinner sheet of denser material (bitumen like) in order to add beneficial mass to your thin rear wall. IME:It's important to secure a ~third of the volume counting from th S1 area to act like a rigid pressure vessel as maximum pressure occurs in the volume just behind the drivers. IMO: Move the drivers as close as possible together,thus a clearance gap a few ~mm at max. b PS: Adding a simple picture suggesting a HPF to be used + a piecewise revision of the picture I left out yesterday. latest posted picture Last edited by bjorno; 1st February 2012 at 02:21 PM. |
| Static on Right Channel Realistic SPA-100 | d1ck | Solid State | 12 | 28th November 2011 04:16 AM |
| philips 2.1 spa 5300 subwoofer not working properly. it uses TDA8947J | avinashpb | Everything Else | 2 | 18th November 2011 05:16 PM |
| Radford SPA-60 schematic wanted | audiomatic | Solid State | 4 | 17th October 2010 06:01 PM |
| Roland SPA-240 amplifier | molesz | Solid State | 1 | 26th November 2009 09:58 AM |
| running 11 speaker cables and 6 interconnects next to each other through a narrow spa | rick57 | Multi-Way | 14 | 17th February 2006 11:35 PM |
| Page generated in 0.06302 seconds (66.27% PHP - 33.73% MySQL) with 11 queries |
