Old 29th January 2012, 07:25 PM   #1
Banned
Default testing a woofer
I have a pair of 12 inch woofers from a subwoofer. I want to test them to see if they are working as they are supposed to. They work, but I keep thinking they dont sound the same as before.
What tests can I do on them?
Old 29th January 2012, 11:45 PM   #2
Well, that's difficult to answer if you don't have any previous measurements to compare. Who is the manufacturer? Is there any part number on the woofers? What was the subwoofer model #? Do they face up or down when mounted?
And THEN, why do you think they don't sound the same?
Old 30th January 2012, 12:11 AM   #3
AllenB is offline AllenB  Australia
Measuring the DC resistance of the voice coils will go a ways toward verifying their integrity. Inspect them mechanically to see whether the coils rub and the suspension and cone are intact. Measure the frequency response.
Verifying that the pair measure similarly will add weight to the thought that they are OK. It sounds as if you have changed their operating conditions lately. Have you relocated them or something else?
Old 30th January 2012, 12:21 AM   #4
TheGimp is offline TheGimp  United States
TheGimp's Avatar
You say you have two woofers "from" a subwoofer. Does this mean that they are removed from the enclosure?
Are you comparing the sound of the drivers to the drivers in the subwoofer enclosure? Or have you been using them out of the enclosure?
Old 30th January 2012, 10:31 AM   #5
Banned
The subwoofer they came out of is the EPIK leggend sub. I dont think there is any label or part number on the drivers so I dont know who the manufacturer is. Could be a custom made unit.
I havent changed anything. I didnt abuse them, I played them within their limits and anyway it has a built in limiter so its hard to damage it.
No. I'm just going by what I remember. I remember the bass being deeper and more even.
Now it seems it doesnt go as deep or the bass is as even. I have tried changing the positioning. I just want to make sure the drive units are working properly.
Old 30th January 2012, 09:14 PM   #6
After a short suspension break in period, very little change occurs in a subwoofer.
If the cone has not become mushy from water damage or really long term punishment, and the voice coil is not dragging, and the suspension appears intact, your perception is probably just from being more aware of LF now than before.
I used to think 40 Hz was low, now that subs with high output in to the teens are easily available, 40 Hz does not seem very deep any more.
Old 30th January 2012, 09:18 PM   #7
Banned
that could be the case. So to test that, I could take a long break from using the subwoofer and come back to it to see what I hear?
Old 30th January 2012, 09:36 PM   #8
Another thing to look at would be room placement. Not only modes from sub location, but bass harmonics due to your mains.
Old 30th January 2012, 10:51 PM   #9
ODougbo is offline ODougbo  United States
Speakers/woofers can last a really long time.
You say you haven't changed "anything"; does that include the hook up wire length? Also, the amp is a plate amp, mounted the speaker(s) - yes? Long speaker wire runs to large drivers can make them sound off.
Old 30th January 2012, 11:02 PM   #10
revboden's Avatar
Are you using the same amp as before?
Do you have any testing equipment? A calibrated mic and some capture software such as REW-5 will help a lot.
Amplification for pro woofer testing Village Plank Multi-Way 3 22nd July 2009 02:10 PM
vented cabinet testing with woofer tester jaya000 Subwoofers 1 17th November 2007 08:39 PM
testing, testing 123 neil_kaye Full Range 0 25th December 2005 08:21 PM
Woofer testing claudio Multi-Way 6 12th September 2002 08:13 PM
Help with woofer testing woody Multi-Way 1 31st August 2002 03:46 AM
Page generated in 0.11672 seconds (81.81% PHP - 18.19% MySQL) with 10 queries
