Old 29th January 2012, 09:22 AM   #1
Default Eminence LAB12 cheaper alternative
I'd like build a pair of subwoofers for my 4PI speakers. The designer, Mr. Parham recommend the LAB12, but here in Europe the price is very-very high( $180 vs. 245 Euro) Can you recommend me similar, but cheaper subwoofer drivers for music listening?
Thanks for help!
Old 29th January 2012, 03:37 PM   #2
epa is offline epa  Netherlands
maybe bms drivers or ciare.
to be sure you have to sim it.
one good thing about music ,when it hit you feel no pain.
so hit me with music
Old 29th January 2012, 06:51 PM   #3
Thanks for help, but I think the Ciare isn't subwoofer ( with 54 Hz Fs), the BMS is expensive too!
Old 29th January 2012, 07:03 PM   #4
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
What are you using the sub for, home theater/ DJ parties/ prosound? What is the desired LF cutoff?
Dan
Old 29th January 2012, 07:17 PM   #5
I'd like use only for music listening, my room's acoustic not too good (the 60-70 hz band iz very thin), and the designer suggest the "flanking" sub configuration eliminathing this. here is my room's sketch:
Description from designer:
AudioRoundTable.com: Speaker => The Subwoofer thing
I haven't got a big room, just only about 13x16 feet, and dont now the desired LF cutoff, but I think 30-35 Hz is enough.
Old 29th January 2012, 08:31 PM   #6
NEO Dan's Avatar
What quality brands are "cheap" where you are?
Dan
Old 29th January 2012, 08:36 PM   #7
I haven't idea... I'd like buy a pair of woofer max 350-400 Euro price.
Old 29th January 2012, 08:53 PM   #8
NEO Dan's Avatar
OK then, what do you plan on powering your subwoofers with? What are you going to use on your Four 𝛑 speakers?
Dan
Old 29th January 2012, 09:01 PM   #9
OK then, what do you plan on powering your subwoofers with? What are you going to use on your Four �� speakers?
I think i will use a class D power amp (L15D or L20D). The 4PI I drive with 300B SE amp.
I don't want too much volume.
Old 29th January 2012, 11:19 PM   #10
If you don't want a ridiculous SPL then I don't think you need pro audio design oriented cabinets / enclosures.
That's what the 12Pi is aimed at...live sound but with good extension.
Is size a concern? (I'm guessing it's not if you were going to build 2 12Pi subwoofers)
Eminence Lab12, ported box sangram Subwoofers 34 13th May 2012 08:56 PM
FS- eminence LAB12 and S2010 Pyroibw Swap Meet 0 12th August 2010 09:56 PM
Eminence Lab12 smallangryboy Subwoofers 17 21st March 2005 03:22 AM
Eminence LAB12 in a dipole woofer? Hennie Subwoofers 3 8th January 2005 09:30 AM
Eminence LAB12/any take on this one? peterpan Multi-Way 4 18th April 2004 06:57 PM
Page generated in 0.10572 seconds (79.39% PHP - 20.61% MySQL) with 11 queries
