#31 |
Alright heres a bunch of info I made today. Included is the input parameters I designed off of, the projected response, a screenshot of the spreadsheet, and the dimensioned drawing I took all of the info off of.
Note that all of the line lengths on the dimensioned drawing must be multiplied by 4 (because the scale of the drawing was 1/4) but I have done this for you in the spreadsheets so you shouldn't have to worry about it at all Most of the corners have a 4in radius piece of sonotube on them to keep the area more constant and this is factored into the numbers The drivers are offset about 7 inches (to the center, i.e. one inch from edge) from the beginning of the horn Let me know if anything else would be helpful. Thanks again! |
#32 |
Oh yeah I forgot to mention that the CSA/Sd ratio is for two woofers, as in CSA/(2*Sd), because I have two. Just trying to avoid confusion
#33 |
#34 | |
I need more time(1-2 days) before I have time to post a more detailed result.. b
#35 | |
b
#36 | |
Would soundproofing material like this work? I have TONS of it. I hate to pay $20 for stuffing material when the whole project cost me at this point like $130 and I already have that. If not what about polyester batting like in quilts, I can get that cheaper.
Thank you! Take however long you need |
#37 | ||
Quilt battings of polyester is a perfect material to substitute 'speaker polyester fibers' as long as the weight/ density is held for the section damping I will suggest later. I guess a combination of denim+your egg crate foam would work well too. Quote:
b
#38 |
Bump...
I'm still fiddling with the stuffing parameters until tomorrow. b
#39 |
Sounds perfect. I've been using it as is for the last few days in my system and I can already tell this thing is insane. Even with the top unsealed and no stuffing it sound leaps and bounds better than my old sub. I can get some serious wall shaking bass with this thing.
I get a bunch of room gain when I'm sitting on top of the thing in the corner. It sounds almost 50% louder then in the rest of the room. Also I get noticeable room pressurization with all the doors and windows closed. I'm powering it off of a 120w plate amp and theres no way I will need that much power. At levels where I'm worried about hearing damage after long term exposure I am still FAR from maxing out the amp, same goes for the woofer excursion. My only real concern is the neighbors
#40 | |
Your sofa sub should be easy to stuff if following this final scheme with minimized use of damping materials but cross-bracing and coverage of internal walls is still necessary if to peak the performance of this design :Part 1 b ![]() PS: I will post Part 2 tomorrow = all plots. |
| Overview about words largest Subwoofer Drivers/Transducers (SUBWOOFER BEAST) | tiefbassuebertr | Subwoofers | 27 | 9th September 2012 09:42 AM |
| DIY Powerful Bass-Shaker for Sofa | kenchu | Subwoofers | 7 | 17th February 2012 02:22 PM |
| LFE Sofa | judderod | Subwoofers | 2 | 19th December 2011 04:55 PM |
| Sofa mounted speaker ... ... ??? | mart34 | Multi-Way | 6 | 15th April 2008 11:38 PM |
