Old 24th January 2012, 05:48 PM   #1
Default How to build Infrasonic Subwoofer for digital organ?
Is the best way to take a 17ft pipe and connect a 12 inch driver to one end of it (if trying to hit 16hz, what about lower)?
Or is there a better way? I'm limited in funds.
Old 24th January 2012, 07:22 PM   #2
Boscoe is offline Boscoe  United Kingdom
Lots of surface area with some very big boxes!
I thought about it once, but then thought again.
Old 24th January 2012, 07:26 PM   #3
chris661's Avatar
How big can this be, and how loud does it need to go?
... and are you sure you want to be able to go that low?
For home use, you could probably get away with a couple of long-throw 12" drivers with some eq (or passive radiators) to get low.
If you wanted to fill a big space with such low frequencies, its not going to be cheap.
Chris
Old 24th January 2012, 07:46 PM   #4
18Hurts is offline 18Hurts  United States
A 16 Hz pipe organ?
I'm guessing loud is required and in the true spirit of such devices... you can get
low and loud as long as you go HUGE early.
Creative Sound - Product Details
The above is a kit with a 12" subwoofer, the drawings and various other things
you'll need to build the monster front loaded horn.
It will go down to 14Hz in a corner and outputs 102dB at one watt in the low range. I'd love to build one but 5 sheets of plywood would make it impossible to move around.
For church use, two of those monsters with a 400 watt per channel Class D amp should do it for you. If you need more than that, it might require a little building modification to withstand those frequencies.
Good luck!
Old 24th January 2012, 08:28 PM   #5
Tapped horns will give you the most bang for the buck.
This one looks good, a recent build confirms it goes low and loud.
http://www.diyaudio.com/forums/subwo...n-2x12-th.html
Works well down to 17.5 Hz, using a pair of JBL GTO1214, should be 120 dB or more depending on room placement.
About 500 liter, 17.65 cubic feet, not terribly huge for the LF extension.
Going lower than 16 Hz will require a longer path length, if the same volume cabinet is used, it will have less overall SPL, and will probably need more expensive drivers.
Old 24th January 2012, 08:52 PM   #6
stoc005 is offline stoc005  United States
stoc005's Avatar
Another approach:
"Cult of the Infinitely Baffled"Hear The Bass, Not The Box The definitive online resource for Infinite Baffle subwoofer designEstablished 1999 - Home
Old 24th January 2012, 10:07 PM   #7
I always wondered what a single CSS Trio12 would do in a single Kraken 1x12 with an extended horn tuned to 16Hz.
The Trio has an Fs of 22Hz and the JBL 28Hz
Trio BL is 14.9 with the JBL at 16.7
Trio Vas is 97 liters and the JBL 58.2 liters
Trio Sd is 491 and JBL at 511
Trio Xmax 20mm and JBL at 14.5mm
Trio Qts is .43 with the JBL at .47
For a pipe organ, in my limited knowledge of tapped horns--would the Trio12 in a tapped horn tuned to 16 Hz be better suited to pipe organs VS the JBL at 18Hz? Is the Trio12 a good woofer for TH or should it only be used in a front loaded horn?
The cost of a Trio12 is about 50% higher than the JBL but if it can be used with a TH tuned to 16Hz--it might be worth it.
How large is the room that this electronic organ will be used? If it is a small room for practice--a much smaller subwoofer can be used. If it's a church and you wish to fill the halls with the 16Hz pipe--it will get very large, very expensive and quite complicated quickly.
Old 24th January 2012, 10:28 PM   #8
Given the specifications, the Trio looks like it should be capable of much more VLF output than a single JBL, but I doubt it could keep up with a pair.
A 22 Hz Fs is much more appropriate for trying to dig below 16 Hz than a 28 Hz Fs.
Maybe someone who likes to model will answer your question with some sims.
Old 24th January 2012, 11:01 PM   #9
Hauptwerk, Allen, Rodgers, Johansen?
Back in '90 I was getting 17Hz in my car with an 8" driver, mild active EQ (+6dB at 20 Hz) and around 40 Watts. It would not have enough SPL in the house though.
Old 28th January 2012, 08:00 PM   #10
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
How to build Infrasonic Subwoofer for digital organ?..(if trying to hit 16hz, what about lower)?..
Hi mikee,
Here is a suggestion of a sub using the Dayton Audio RSS390HF-4 driver in a folded T-TQWT:
b
Subwoofer build - Morel UW1258, 12" Ultimate Subwoofer mantha3 Subwoofers 46 10th October 2011 01:11 PM
Infrasonic Addiction ... FlipC Subwoofers 31 10th October 2009 01:39 AM
Infrasonic Headphones? transcendemotio Everything Else 2 14th May 2009 10:08 AM
Ideas as to what is inside? Need 16Hz for digital pipe organ-help? asiquis Subwoofers 30 18th July 2007 05:18 AM
Infrasonic Bass Generator G.C.H. Subwoofers 2 2nd July 2004 03:38 PM
Page generated in 0.12273 seconds (80.95% PHP - 19.05% MySQL) with 11 queries
