A friend's upstairs HT / listening room is unfortunately near cubical apart from being partly open to a large vaulted area on one side. No matter what we try, there seems to be some sort of bass / mid bass suckout.
What are our best options? DIY is no problem and I have a variety of drivers available. Thanks
"Any fool can know. The point is to understand" - Albert Einstein Last edited by zobsky; 24th January 2012 at 04:05 PM. |
#2 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
You can try putting some muckets in the floor, courtains or some other absorbent material to stop standing waves in the room. I believe that if the place where it is not acoustical, few things can you do in the audio equipment, except a parametric equalizer and attenuate all resonant frequencies in the audio program being reproduced.
LW1DSE |
#3 |
Try covering the opening to the vaulted area with a piece of plywood, if that works a door could be installed, or a rolling divider made.
#4 |
Cubic room
... ... :Probably more than 2 subs would be a fruitful cure.. b |
#5 |
lots of absorbtion to make the room have a less high Q resonance.
CHR-70+Subs |
#6 |
bjorno, you have some GREAT audio software over there!
#7 |
Hi, BP1Fanatic: I just picked a free tool I found to be useful for this purpose:
Room Response Calculator - Reflective Accumulation Simulation Software b |
#8 | |
FWIW... I've loaned my friend my T-TQWT 12" shiva sub for now (I know you're a fan of these enclosures).
"Any fool can know. The point is to understand" - Albert Einstein |
#9 |
suck-out you say. What you've got there is phase cancellation. One of the distances of the sub to one of the boundaries is 1/4 wavelength of the frequency being cancelled. Figure out what frequency is being canceled and you will be able to tell which reflection is causing it.
He's going to need careful placement and multiple subs placed at varying distances from boundaries so the suck-out one sub experiences is covered by the others. Last edited by revboden; 24th January 2012 at 09:07 PM. |
#10 | |
The difference made by simply placing a gobo in front of the opening was obvious even without any test gear, the control room smoothed in response by an order of magnitude (as confirmed by the test gear). No speaker position changes or additions were needed. I hardly made any money on that consultation ![]() Art |
| Cubical Panels for Listening Room? | mpuman | Everything Else | 0 | 12th September 2011 05:39 PM |
| The Missing element in Chipamps> how to achieve tight kick drum bass with chipamp? | rhythmdiy | Chip Amps | 28 | 14th August 2008 08:04 AM |
| subs to get the best bass in my room ... | paulspencer | Subwoofers | 6 | 10th September 2004 03:35 PM |
| how do i achieve this kind of bass.. | ChesterFuzzin' | Multi-Way | 10 | 9th July 2004 03:22 PM |
| bass is in the wrong room.... | SkinnyBoy | Everything Else | 2 | 29th January 2004 03:45 AM |
| Page generated in 0.10423 seconds (80.62% PHP - 19.38% MySQL) with 11 queries |
