I made my subwoofer an year ago. It sounds good. but recently when I touched it while it was on, I found vibrations. when It was newly built I never checked if it vibrates. I used 18mm MDF with 200mm woofer. I wonder why does it happen so? It happens even at the volume level is low.I am attaching the pic of the sub woofer cabinet for better understanding of its structure. please help me to understand the problem.
There is always a first time.... |
#3 |
Yes, when I realized that the enclosure vibrates I kept the music going on . lowered the volume to very low. thinking that the vibrating might be because of high volume output.
I understand something might be wrong in shape of it, that results in vibration. but then what is it ?
#4 | |
Try sitting on the enclosure and see if you still feel the vibration. Feel the floor, it probably is vibrating as much as the cabinet. Excessive cabinet wall flex, which would be unlikely in a cabinet as small as yours with 18mm MDF, can be fixed with bracing. Since it sounds good, don't mess with it |
#5 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I have 3 Karlson speaker enclosures, 2 of them 15" plus a 4" tweeter, and a 3rd 12"+4". Although the construction is very rigid per se, and the speakers ar rated for 70W, and I´m using only 12W max from TDA2006, I can tell you allways a small amount of vibrating in the walls must be, because internal pressures are very big and the waffle walls are not perfectly rigid. You can do a simple test to see what happen in it. I read it in some audio magazine from 70's in Argentina wrote by Saul Sorin or Julio V. Rueda (I believe): you need an audio generator and some dry sand. Put the cabinet in some fixed location, on the floor. Place over the top, some sand, set the generator in the lower frequency as you can, and increase it slowly. You can see that the sand separates and joint forming the nodes and peaks of the standing wave, and if you continue augmenting frequency can see the harmonics of it. Try this in the faces except that one containing the speaker. If the frequency of all faces are equal, then try some absorbent material inside the cabinet, but not near the walls, because it doesn´t do nothing, air velocity near the wall is zero. And, you can try some strengthen or encourage (Sorry if my english is not so good) by means of a piece of wood in the places where standing waves are most important. But have in mind that zero vibrating can be done if and only if rigidity of walls are infinite.
Good luck.
LW1DSE Last edited by Osvaldo de Banfield; 24th January 2012 at 03:21 PM. |
#7 | ||
Thank You for the help and suggestions.
Yet the amplifier is not placed on subwoofer cabinet so sure thats not the reason.
#8 |
#9 |
A similar problem was discussed a few weeks ago; do you happen to see this?
Subwoofer box rattle issue |
#10 |
friends, I will get back here after sometime. I am not well got HAI ( hospital acquired infection) hope i recover soon.
| Subwoofer enclosure Non-parallel enclosure to reduce standing waves | qguy | Subwoofers | 4 | 4th July 2011 09:35 PM |
| Vibrating capacitor | blue lander | Tubes / Valves | 14 | 11th February 2011 03:50 AM |
| Help with my Transformer - vibrating | Brit01 | Tubes / Valves | 10 | 26th July 2009 04:40 AM |
| Why is my amp vibrating? | wwenze | Chip Amps | 4 | 13th May 2009 03:50 PM |
| Vibrating cutter...any available | gmphadte | Parts | 10 | 7th December 2007 08:10 AM |
| Page generated in 0.11115 seconds (83.35% PHP - 16.65% MySQL) with 11 queries |
