I keep eyeing the MCM 21" cast woofer. The specs look tempting. Interesting, though when I enter the data into WinISD, the curve is identical to the 55-2984 cast 18 woofer. with a xmax of 7mm and a vas of 705 litres, I expected a different result. Any input
#2 |
I have tested several other MCM drivers and with the exception of the 55-2421 they were all quite a bit off. Generally speaking the motor force is quite low causing a major problem with Q values and sensitivity. You get what you pay for.
Regards, Dan |
#3 |
Greetings kegent01. I eyed this thing as well. That's why I'm in the closing stages of building a tapped horn for mine. nothing fancy, just wanted to try it. Should be ready to test by Wednesday. I'll keep you posted.
#4 |
Thanks. I am currently building an 18" version Bass cab
#5 |
Try the 18sound 21lw1400. It's 360 I believe from loudspeakersplus.com
http://www.loudspeakersplus.com/prod...SOUND21LW1400/ After using the 18lw2400 in my TH-18's id love to try out a cabinet designed around the 21 incher!! Last edited by m R g S r; 2nd February 2012 at 09:40 PM. |
| PE Buyout 6" shielded AL cast frame woofer | AdamThorne | Multi-Way | 1 | 18th April 2008 11:28 PM |
| MCM 12" pro woofer? | AdamThorne | Multi-Way | 2 | 14th September 2007 01:53 PM |
| Question regarding the MCM 8" Woofer (Part #55-2421) | Phlim | Subwoofers | 2 | 2nd February 2006 10:46 PM |
| Looking for 55-1875 MCM 18" woofer box design | lXxAndyxXl | Multi-Way | 7 | 28th September 2004 03:32 PM |
| FS: Focal 7K4411 - Seas 27TFFC - MCM 55-1855 - Free PE 5.25" DOTD woofer | PaulHilgeman | Swap Meet | 1 | 23rd July 2003 09:36 PM |
| Page generated in 0.10167 seconds (67.22% PHP - 32.78% MySQL) with 10 queries |
