I have enclosure plans that call for four ports, 2.38" ID x 3.5" long. I was playing around with the AJ Vented Designer application and came up with these alternatives using two ports instead of four:
1) 2.38" ID x 0.88" long 2) 2.75" ID x 1.49" long 3) 3.00" ID x 1.97" long 4) 4.00" ID x 4.48" long Does the math look right here? If yes, is there a preferred choice? Thanks, dooper |
#2 |
Bigger and longer is better for speakers with big displacement.
The disadvantage of large ports is the port area needs to be deducted from cabinet volume, so you end up with a larger box. The port size estimates look reasonable. |
#3 |
What is the box volume?
#4 |
#5 |
1. 50.2Hz
2. 50.6Hz 3. 50.8Hz 4. 51.7Hz Have you tried 'Boxnotes' and 'Flare-it'? Very handy for figuring out port velocity requirements. |
#6 |
Thanks -- I'll check that out!
#7 |
| Goldwood 12" Vented box question | ostripper | Multi-Way | 2 | 15th January 2011 12:37 AM |
| In Bass reflex box (vented)-If I make smaller box than what consequences will I have? | eliaselias_0 | Multi-Way | 6 | 3rd January 2011 03:49 PM |
| Flared ports and dual vented / sealed design | Dave Bullet | Multi-Way | 3 | 23rd October 2002 12:04 PM |
| Vented box design question | thylantyr | Multi-Way | 4 | 1st October 2002 07:01 AM |
| Vented enclosures: ports at the front or rear? | Sud | Multi-Way | 4 | 17th September 2002 07:49 AM |
| Page generated in 0.07897 seconds (75.49% PHP - 24.51% MySQL) with 10 queries |
