Old 26th January 2012, 08:47 PM   #11
basite is offline basite  Belgium
Thanks, will be taken in consideration
In the meanwhile, I've been experimenting a little (this will end up in being one big experiment...)
I added an equalizer, +5db @ 26hz, and -8 @ 55hz, and now I have a fairly good response simulation in a 90L box. Might actually build this...
-6db @26hz, -3 @ 37hz, subs will be placed in a corner, against wall, on the floor, so I'm hoping for some extra here.
Another question: in winISD there is an option to add mass to the woofer cone, is this actually done too, or avoid at all costs? adding like 10g in the simulation gave good results too.. (do mind, these drivers were virtually free, and not *that* special, if it won't do bad to the driver, I might as well try?)
and, what are the effects of glass wool in the box?
Thanks,
Keep them spinning,
Bert.
T/s specs for Memphis LVs dual spider/basket 12 inch muddasirwaheedmalik Subwoofers 4 12th December 2011 05:53 PM
Utah 12 inch dual concentric & coaxial? Uhills Full Range 1 12th May 2010 07:50 PM
Dual 12" Subwoofer Project ReTrO Subwoofers 78 20th March 2010 10:31 PM
Opinions Wanted on Dual 12" Subwoofer Project Sithlord2007 Subwoofers 20 19th September 2008 04:46 AM
Celestion G-18C and Tannoy dual concentric 12 inch both 100 W! Should I get them ? VvvvvV Multi-Way 0 17th May 2005 06:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
