Old 18th January 2012, 05:36 AM   #1
lawrst is offline lawrst  Australia
Default Help me with ideas for a dual 10 inch subwoofer box
Long story short I have 2 10 inch Pioneer Car subs Model TS-W255C That I have no use for.
So im looking to have a bit of a play with them and make something cool. Doesnt have to use both, but again would be nice.
Throw out some options, try to keep the box size reasonable.
What do people think would work well with this sub, i mapped out a vented box of 30L to 35hz but that seems a bit boring.
Thanks in advance for the help
Old 18th January 2012, 08:13 AM   #2
col is offline col  Australia
col's Avatar
maybe you could do a version of the ODougbo isobaric.
Isobaric - less then $20
col.
http://www.minirig.org.au
Old 18th January 2012, 08:40 AM   #3
ODougbo is offline ODougbo  United States
Hi, Don't think car woofers are candate for an Iso build, they work in small boxes in the 1st place, so probably can't cut that in half. And you want to keep the box reasonable, so the T-TQWT is out.
What about a band-pass?
Can you post the specs?
Old 18th January 2012, 08:57 AM   #4
col's Avatar
Another option if you are into electronics it to put them in very small sealed boxes and then run the signal through either a linkwitz transform or the ESP Electronically Assisted Subwoofer (EAS) circuit. I actually run 2 low profile Pioneer 10" subs in this way in a small apartment. The low bass they achieve is uncanny.
Sub-Woofer Controller
or if you can afford the PCB:
P48 Sub-Woofer Controller (Rev-A)
col.
Old 18th January 2012, 06:49 PM   #5
I tried to model the sub/subs in a bandpass design but it didnt look pretty.
These are the only specs i could find
They were from Pioneer TS-W255C 10" 4-ohm Component Subwoofer - Features & Specs at Crutchfield.com
I will say that a folding horn sub does intrigue me a lot.
Im no expert, in fact i am a box design virgin, this will be the first box i make of sorta my own design. The others I have made have been manufactures specs for car subs.
Old 18th January 2012, 08:35 PM   #6
chris661's Avatar
Put them magnet-to-magnet in a small as possible box. Add some serious low-end boost. Tiny box, big sound. (lots of power needed)
Chris
Old 18th January 2012, 11:56 PM   #7
Not sure what this means, are you referring to using a controller as refrenced above.
Old 19th January 2012, 01:05 AM   #8
frugal-phile(tm)
planet10's Avatar
Pioneer suggests 1 ft^3 sealed. Data here
I'd mount the pair push-push in a 2 ft^3 box.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th January 2012, 01:07 AM   #9
nigelwright7557's Avatar
How about a folded horn box ?
They are very efficient and give out loads of bass.
They dont have to be huge.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 19th January 2012, 05:20 AM   #10
Folded horns are tempting, just unsure where to start with a design.
What would push-push do exactly for them that a side by side mounting wouldn't?
Tannoy 10 inch Dual Concentrics JRKO Multi-Way 120 10th April 2011 12:14 PM
which 10 inch driver in a sealed box qguy Subwoofers 26 9th December 2008 04:55 PM
Tannoy 10 inch dual in a Metronome or Monolith? beeroclock Full Range 0 31st May 2007 04:05 PM
Page generated in 0.10878 seconds (80.02% PHP - 19.98% MySQL) with 11 queries
