Old 17th January 2012, 07:00 PM   #51
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Just thinking about these type of enclosures; if one were to leave the top off and just flip it upside down on the carpet you could probably get by for testing as long as you weighted it down sufficiently to prevent any leaks or rattles.
Dan
Old 17th January 2012, 07:02 PM   #52
NEO Dan's Avatar
~26Hz, but it'll be a bit lower with the stuffing.
Dan
Old 17th January 2012, 08:29 PM   #53
NEO Dan's Avatar
Lower yet now that I think about it. I think this will need stuffed for the additional length of the bottom section. Would imagine it will push you into the low 20Hz range. I'll send data to b and see if he has a comment.
Dan
Old 18th January 2012, 02:54 AM   #54
BP1Fanatic's Avatar
I went to vote for you NeoDan, but I don't do FaceBook or Tweet. That F1 car is NASTY tho'!!!
Old 18th January 2012, 10:29 AM   #55
NEO Dan's Avatar
LOL,
Hope you are kidding BP1, I don't have anything entered. I am considering buying the render plugin though.
Dan
Old 18th January 2012, 01:20 PM   #56
okay so if i stuff the box it should bring the tuning down, and hopefull i wont get port noise
Old 18th January 2012, 02:43 PM   #57
NEO Dan's Avatar
Stuffing will be necessary for reasons other than LF tuning, the stuffing is also used to dampen the resonant modes that occur at the upper end of the range. What do you use for a crossover to filter the high frequencys from the subwoofer? It'll sound like shite if you don't use a filter. Really you should have filtering to remove content on both the high and low ends of the spectrum, filtering off the lows below tuning will help protect against bottoming the drivers.
Dan
Old 18th January 2012, 03:05 PM   #58
i use a passive crossover as my amp doesnt have a low pass filter, it cuts off around 100hz
Old 18th January 2012, 03:28 PM   #59
NEO Dan's Avatar
So you run the whole system off the Denon?
Dan
Old 18th January 2012, 04:43 PM   #60
no i run a pair off q acoustics 2020 of the denon, and i have a power amplifier (pa amplifier) which is 250 watts rms to each channel that i use for my subs, with passive crossovers
Entering horn meaurements fora folded horn (hornsrep) Tidy Max Software Tools 3 21st February 2011 02:28 AM
would these be ok in a tapped horn or folded, any ideas, i got two the price is good mastadon Subwoofers 19 25th December 2010 03:02 AM
2" tapped or folded horn? bnbgn Subwoofers 17 3rd December 2010 01:21 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
Copyright ©1999-2013 diyAudio
