jbl gto804 tapped horn/ folded horn
Old 15th January 2012, 09:13 PM   #31
tb46 is offline tb46  United States
Hi 2009thread1,
Do you have any idea on a preferred size? When I simulate a TH (for a single JBL GTO804D) in Hornresp I get something around 95/110 L_net. For a tapped horn with a long folded horn path that may mean 125/130 L_gross. Your preferred external size will determine the folding.
Oliver
Old 15th January 2012, 09:20 PM   #32
2009thread1 is offline 2009thread1
if i can get it out of one sheet of mdf that would do, if it needs to be big for the sound i should be able to fit in somewhere
if you can sketch it up and email it to me on google sketchup i'd really appreciate it
Old 15th January 2012, 09:34 PM   #33
Hi 2009thread1,
I haven't found time (or reason, I use ACAD) to learn Google sketchup, maybe NEO Dan can help. I'll attach a first try Hornresp input and spl window:
Oliver
Old 15th January 2012, 09:38 PM   #34
thanks, if the tapped horn idea is going to be really big i'll go with the t-line enclosure
Old 15th January 2012, 09:46 PM   #35
ODougbo is offline ODougbo  United States
Default P2D28 8"
Just had thought, I have a couple of these unused.
Rockford Fosgate
Fs (Hz): 40.0
Re (Ohms): 3.50
Le (mH): 2.5
Qts: 0.45
Qes: 0.48
Qms: 6.00
Cms (m/N): 0.18
Vas (L): 10.0
Mms (g): 88.5
Mmd (g): 86.9
Rms (kg/s): 3.7
Airload (g): 1.6
SPL (dB - 1W/1M): 84.0
BL (T*M): 13.0
Woofer Displacement: 0.85 0.030 liters | cubic ft
Power Rating: 200 400 RMS | Peak
Linear Excursion, pk-pk (Xmax): 0.315 8.0 inches | mm
Sd (cm2): 200
Old 15th January 2012, 10:12 PM   #36
Hi 2009thread1,
The sketchup TL looks like 72.38 L_gross, that is a lot smaller. But which one is better? :-)
Oliver
Old 15th January 2012, 11:02 PM   #37
And for what it's worth the SPL response of the sketchup TL:
Oliver
Old 16th January 2012, 06:17 AM   #38
Rockford Fosgate
i live in the uk so buying from america will be expensive, how would the rockford fosgates hold out on 250 watts rms ?
ive never heard a t-line before, but from videos they're really loud on the lows, but ive never heard an 8" tapped horn before
Old 16th January 2012, 01:33 PM   #39
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Originally Posted by tb46 View Post
Hi 2009thread1,
Don't be looking at me - your the one with AutoCAD
It's not like you need AutoCAD to get good looking output either:
Go have a look and VOTE
Dan
Old 16th January 2012, 02:07 PM   #40
Amen Brother Neo.
jbl gto804 tapped horn/ folded hornHide this!Advertise here!
Entering horn meaurements fora folded horn (hornsrep) Tidy Max Software Tools 3 21st February 2011 02:28 AM
would these be ok in a tapped horn or folded, any ideas, i got two the price is good mastadon Subwoofers 19 25th December 2010 03:02 AM
2" tapped or folded horn? bnbgn Subwoofers 17 3rd December 2010 01:21 AM
Ron's Austin II, old T-Horn, Lab12 Tapped horn, CNC Photo Background layertone Full Range 2 23rd December 2009 12:51 AM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
