I have heard that most of the cheaper rta mic
#2 |
what I meant was, I have heard that most of the cheaper rta mic's dont do very well at 20hz and are not consistent. Can anyone recommend an RTA mic for subwoofers?
Cheap is good but only if its good enough. thanks, |
#3 | |
The same element is used on several other test mics costing more than the RTA-420. I have a pair of very expensive test mics, B&K 4004, some info about the RTA-420 compared here: PSW Sound Reinforcement Forums: LAB: The Classic Live Audio Board => Testing the Test Microphone The picture below shows the RTA-420 is 4 dB down at 16 Hz from the 4004s, the test source obviously is not flat, but both mics were placed as close as possible to the same position. The B&K 4004 came with an individual test sheets, they are (were) +/- 2dB from 10 Hz -40 KHZ. The B&Ks have hardly left the mic locker since getting the RTA-420, if I have a speaker that produces anything much below 30 Hz I can just refer to the comparison and add a few dB appropriately. Art |
#4 |
#5 | |
I first used an electret mic element from a telephone, I was amazed that it had far flatter response than I expected. Then I ordered several Panasonic elements, the pair of WM62 and a phone unit are compared to the RTA-420 below. The phone unit has a midrange boost and HF rolloff. One of the WM62 “A” has a reduced LF, even though the upper response matches the RTA-420 pretty well, and seems to be picking up 60Hz and harmonics. Funny, just dug them out of the mic closet the other day, your post made me curious to test the response out. The 9V batteries were all pretty low after 13 years of storage... Anybody wanting some cheap test mics can PM me :^). Art |
#6 |
I ended up just going with a dbx RTA-M which is said to be very similar to the discontinued SIA RTA-420.
I went with this since I live in aus its fairly available here and I am not good at making electronics nor would I trust myself making an rta mic. |
#7 |
If you had a spare 700USD laying around you could have bought a Term-LAB measurement system. It uses a pressure sensor instead of a microphone.
http://www.termpro.com/storefront/page605.html
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#8 |
haha, yes, that's cheap lol. but maybe doable when I do gigs for more than a thousand people
#9 | |
I suspect most of these cheaper mics probably use the same elements anyway, the (working) Panasonic WM62 is almost a direct overlay of the SIA RTA-420. I have a DOD RTA mic that measures about the same too. Considering how drastically measurements vary with position, spending more than $100 or so on test mics is hardly warranted unless you are getting paid big money for the measurements. |
#10 |
Yeah, I suspected I would be much better off with this than something the likes of behringer...
| DBX RTA-M measurement mic,M audio fast track usb. Quick sale | tomat | Swap Meet | 6 | 21st September 2011 03:09 AM |
| Beyer MM-1 RTA Mic Best Budget RTA Mic | Zero Cool | Swap Meet | 3 | 5th May 2009 05:32 AM |
| WTB: ScanSpeak 15Ws, RTA mic, DCX2496, 60vct or 70vct transformers. | Spasticteapot | Swap Meet | 5 | 12th January 2009 09:54 PM |
| WTB: Behringer (or other) RTA Mic | seagrasser | Swap Meet | 1 | 11th January 2009 07:00 PM |
| RTA mic | kan3 | Multi-Way | 3 | 4th February 2004 09:52 AM |
| Page generated in 0.09811 seconds (81.31% PHP - 18.69% MySQL) with 11 queries |
