Old 30th December 2011, 05:19 PM   #1
amjulio is offline amjulio  Argentina
Default Horn HOM & aspect ratio
Earl Geddes warns against High Order Modes (HOM ) in horns.
I designed my horn using Hornresp. Instead of use a the Hornresp square section I used a rectangular one (equal area of course, see atachment aspect ratio.png).
For instance I get 105.8cm2 with a 20.6x5.1cm2 instead a square with side 10.2cm
Do you think using un aspect ratio different than one could bring some trouble, may be HOM generation?
Horn loaded JXR6 which contour HOM suppression jzagaja Full Range 12 19th October 2010 11:46 AM
horn with low compression ratio patriz Multi-Way 6 17th May 2006 10:45 PM
Page generated in 0.06129 seconds (63.22% PHP - 36.78% MySQL) with 11 queries
