| Thread Tools | Search this Thread |
Some may be familiar with the design, although I used cardboard tubes instead of a slot port.
Also ran this in WinISD and Perfect Box; the results were similar so went with a 1cf box and dual ports 16” long [the next box I may go back to a slot port] The woofers are 6 ½” Factory Buyout, I bought 4 for $8 each. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-114 They modeled okay; it does have a bit of a shark tail contour, 3db increase at 25hz. I’ve been adding a little extra at the bottom for such a long time I don’t think I would like anything else. This Isobaric box appears to have some power, a few more easy steps and I’ll do a final glue up. I like to clamp and check the tuning before final assembly. I was pleasantly surprised, the tuning and the response was as expected (and some 25hz bass). Not a bad little woofer, the surround is light rubber; I wish it had more than 4 holes [they say never drill a basket]. The laminate rings are pretty easy, it only took three rings; i.e. the woofers are 2-¾” apart. *I also added a 10" PR ($18) to the last order, I wouldn't mind trying that with the next build. |
#2 |
Where do you put them all, do you put bows on them and "gift" them away?
Regards, Dan |
#3 |
Sometimes I give them away (no bow) OR for trade. Sounds like you would like to have one NEO.
I'd go for the MCM 8” versions; you'll be doing back flips in the back yard if you hear one of them. |
#4 |
Although I do have the drivers on the shelf I'm not a small sub person. I look at your subs and think about the >$30 sheet of MDF, if I'm buying a sheet of material I might as well get all the box/performance out of it I can.
Regards, Dan |
#5 |
My first post ever on diy. Your isobaric inspires me to get to a project I've had on the shelf for a few years. I have 8 vifa 8" woffers from a speaker that ended up not working. I want to build a double isobaric with 4 per side and mate that up with a 4" vifa mid and a vifa tweeter.Crossover will be simple to start as that is a very weak area for me.This will take time but I"ve been sitting on these drivers for a few years so what's a while longer? Thanks for the kick in the pants.
#6 |
If I was to describe the sound, it’s a slam, bubble and/or chug. I have a MCM 8” Iso in the shop, it reaches out and grabs you.
The two in the HT I moved up on 12” metal stands; should have done that long ago, it was a big improvement (by adding detail in the bass). I find them remarkable. 8 working Vifa woofers? What’s the model #? |
#7 |
What are you using to power them, plate amps?
Regards, Dan |
#8 |
I don't use plate amps (do have one on the bench) I've been using, Rotel, 120 watt stereo amps, e.g. RB 980BX. I had an Adcom 60watt stereo amp powering one for a long time, it had a very nice sound.
I'll try this 6-1/2” Iso in shop, HT and maybe even the truck cab; that 25hz would sound great in a cab. |
#9 |
Great photos, it makes me want to build one too. I've think you've got $200 worth of clamps on top of $16 worth of drivers. Hee hee.
#10 |
Clamps are not that bad $$ ~ HD has a nice selection, buy a couple a year, they build up fast.
Hey weights work well too, 25lb – 40lb dumbbells work great for “clamping”. Last edited by ODougbo; 29th December 2011 at 02:48 AM. Reason: lb |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| mightym, pop4richard |
| 20 Hz to 20 kHz Dipole Speaker System | MJK | Full Range | 69 | 29th September 2008 01:37 PM |
| Power Amp Toroids 20-0-20 VAC 500 VA | daedalus | Swap Meet | 17 | 24th May 2006 07:30 PM |
| Mullard 5-20/Maplin 4-20 modification to NON-Ultra Linear mode???? | vinyvamos | Tubes / Valves | 1 | 28th January 2006 04:07 PM |
| Page generated in 0.07498 seconds (77.22% PHP - 22.78% MySQL) with 11 queries |
