Old 1st February 2012, 11:50 PM   #241
ODougbo is offline ODougbo  United States
Thinking about adding a small piece where the two boxes meet, although I just noticed the plan has a small triangle.
Old 2nd February 2012, 12:10 AM   #242
BP1Fanatic's Avatar
Did you take 2 existing boxes apart to make 1 big 1?
Old 2nd February 2012, 03:09 PM   #243
tb46 is offline tb46  United States
Default Post #241
Your straight board solution would work just fine.
Oliver
Old 2nd February 2012, 03:30 PM   #244
Only took the "bottom" of one box, will build to piece-by-piece.
Old 2nd February 2012, 03:33 PM   #245
Sometimes it helps to look at my own pics......I laminated some boards together, will cut on band saw.
Idea stolen from a recent thread
Old 2nd February 2012, 03:36 PM   #246
Hi ODougbo,
When you "laminate boards together" do you use bisquits, or any kind of reinforcement/alignment?
Oliver
Old 2nd February 2012, 03:41 PM   #247
nope lots of glue....biscuits/dowels are for "ends", which I'm going to do for this build.
A little dowel jig is good to have around!!! I'll take some pics.
Old 2nd February 2012, 03:43 PM   #248
Hi again,
Pictures are worth.... :-).
Oliver
Old 2nd February 2012, 08:05 PM   #249
BP1Fanatic's Avatar
LOL!!!
Old 2nd February 2012, 08:10 PM   #250
Default Pic
The divider may be too big, only 2-3/4" at the inside corner.
The dowel jig is old but works as good as ever, you just buy the dowel inserts.
20 Hz to 20 kHz Dipole Speaker System MJK Full Range 69 29th September 2008 01:37 PM
Power Amp Toroids 20-0-20 VAC 500 VA daedalus Swap Meet 17 24th May 2006 07:30 PM
Mullard 5-20/Maplin 4-20 modification to NON-Ultra Linear mode???? vinyvamos Tubes / Valves 1 28th January 2006 04:07 PM
Copyright ©1999-2013 diyAudio
